Error #10052
Dalena
Receive the following error:
  • ifort: error #10052: could not checkout FLEXlm license
Despite having the license in the correct folder:
C:\Program Files (x86)\Common Files\Intel\Licenses
And being connected to the appropriate networks.
mecej4
It appears as if you are trying to use Intel Fortran 2015 from PSCAD, and your license for that old version of the compiler is no longer valid. If you wish to continue using that version, you  may need to obtain a new license file, and you will need to contact Support for that. Or, if your version of PSCAD is compatible with the current release, you can obtain and install the current release of the Fortran compiler (the HPC toolkit).
Steve_Lionel
The screenshot doesn't show enough of the license messages to properly diagnose an issue. Intel compiler licenses do not expire, unless they are non-commercial or evaluation. License questions are better handled through the Online Service Center.
