I 've moved old code .F90 to dot:net2003 & Intel 8.0 .The program start with:
integer*4
function WinMain(hInstance, hPrevInstance, lpCmdLine, nCmdShow)linkerror:
Error LNK2001: unresolved external symbol _WinMainCRTStartup
fatal error LNK1120: 1 unresolved externals
ChangingEntry point in the links panel - did not work.
Any idea what is it wrong?
Ted
The error has nothing to do with your code - there's a problem in how you're linking the program in that it is missing some reference to the MSVC libraries. How did you create the project?
Please note that Intel Fortran 8.0 is no longer supported.
