29233 討論
Error in documentation of COMPILER_VERSION
mecej4
榮譽貢獻者 III
1,347 檢視
The OneAPI Fortran compiler developer reference guide gives the following code to illustrate the usage of the intrinsic COMPILER_VERSION:
program pvers
use ISO_FORTRAN_ENV
character (len = :), allocatable :: res
res = compiler_version ()
print *, "len of res is: ", len (res)
print *, "('<<', A, '>>')", res
deallocate (res)
close (1)
end
On line-8, *, should not be present.  Line-11 does not belong, either.
7 回應
FortranFan
榮譽貢獻者 III
1,317 檢視
Good catch @mecej4 .
Intel Team,
Can you please also review the following toward any update to the documentation?
  1. The two standard inquiry functions, COMPILER_VERSION and COMPILER_OPTIONS, go hand in hand.
  2. The information returned by the two functions is essentially a compile-time string constant, thus users may be better off defining a named constant of CHARACTER type toward the same rather than variables
  3. Thus an initial sketch of an example to be included in the documentation may be as follows that your writer(s) can edit as deemed suitable:
program CompilerVerandOptions
   use, intrinsic :: iso_fortran_env, only : compiler_version, compiler_options
   character(len=*), parameter :: cver = compiler_version()
   character(len=*), parameter :: copts = compiler_options()
   print *, "Compiler Version: ", cver
   print *, "Compiler Options: ", copts
end program
C:\temp>ifort /standard-semantics CompilerVerandOptions.f90
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.8.0 Build 20221119_000000
Copyright (C) 1985-2022 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.34.31937.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:CompilerVerandOptions.exe
-subsystem:console
CompilerVerandOptions.obj
C:\temp>CompilerVerandOptions.exe
 Compiler Version:
 Compiler Options: /standard-semantics
C:\temp>
JohnNichols
傑出貢獻者 III
1,311 檢視
   write(*,100)cver
100 Format(   "Compiler Version: "//,(A),/)
   write(*,200)copts
200 Format(   "Compiler Options: "//,(A),//)
end program
This gives you a bit cleaner output that is easier to read.
Just of interest should not the use of Close(1) as noted by @mecej4  not generate a warning as the file was not opened.
See below.
Barbara_P_Intel
1,286 檢視
Definitely a GOOD CATCH! I filed a bug report, DOC-10851. The change might just make the next release.
I was in a meeting recently where the documentation team said they are planning to test the sample code in the DGRs (Developer Guide and Reference). That will be cool!
Barbara_P_Intel
1,284 檢視
Are you guys going to want royalties for these new examples? Best I can do is kudos.
FortranFan
榮譽貢獻者 III
1,264 檢視
@Barbara_P_Intel ,
Yes, I would want royalties please!!!  In the form of more code examples with some real style by Intel writers in Fortran DRG for the benefit of oneAPI users!
JohnNichols
傑出貢獻者 III
1,239 檢視
I spotted a code error in the MS Powerstation Reference Manual, and then promptly lost it.
It was write(*,))SOMETHING   Of course it is long past, but even the best make errors.
Barbara_P_Intel
1,147 檢視
This is fixed the next release of oneAPI coming this spring.
回覆
