I have a project which will create static library. I use it a lot and it was ok.
Now, when it is compiled, it shows many errors such as:
error #7002: Error in opening the compiled module file. Check INCLUDE paths.
I rebuild the solution. Errors are still the same.
The source files are all put in a directory. So I think I don't need to set the Additional Include Directories.
What are the possible problems?
Thank you in advance.
Mike
Mike
It's very strange.
That library worked well before. Now, I add a subroutine.
Then it has this error.
I comment the added subroutine.
Rebuild it. There is no error.
After uncommentting it, there is no error again.
How come?
Mike
It's very strange.
How come?
Mike
I don't have enough data to debug the problem, just a couple of hints:
- The message "Error in opening the compiled module file" means that the compiler can not locate the .mod file. The Foo.mod file is expected when compiler encounter "USE Foo" in a source file.
- That message is normally accompanied with a module name (although I didn't check in 11.0) -- is it?
- When you use MODULEs and build them in a static library, you (usually) also need to distribute the .mod files along with the lib, in order to build the .exe. (Or give the compiler the appropriate INCLUDE path). Is that the caes, or you're encountering the problem while building the .lib itself?
If you don't use MODULEs at all, you might have encountered a compiler bug. A wild guess for a workaround is that you remove /gen-interfaces (Fortran/Diagnostics) and /check-interfaces, but that's just a wild guess. You should give us some more data to work with.
Thank you very much for your reply, Jugoslav. Your informations are always helpful.
The problem now I figure out is due to cyclic dependency, as I also encounter repeated compiling even without any modification of programs. I have also posted in http://software.intel.com/en-us/forums/showthread.php?t=62386.
Mike
I'm getting a similar error that I haven't been able to solve. I'm just trying to check that the IMSL Library was properly installed following http://www.vni.com/tech/imsl/gettingStarted/using/use_for_win.php
But I get this Error:
Error 1 error #7002: Error in opening the compiled module file. Check INCLUDE paths. [LSARG_INT]
I have added the
How can I prove that such path is properly set?
Thank you,
I suggest following the instructions in the Intel Fortran documentation under Building Applications > Using Libraries > Using IMSL
I also followed the instructions as you suggested. Not even adding the imsl.lib and imsl_dll.lib libraries in the Source files helped.
I still get the same error.
Thank you,
Thank you,
I have a similar problem. I want to use fftw3 library in a fortran program. I downloaded the DLLs from fftw.org and I extracted the .lib files with:
lib /def:libfftw3-3.defMy code is similar to:
[bash] Program bFFTW ! use libfftw3 !DEC$ OBJCOMMENT LIB:'libfftw3.lib' integer :: Num,jres,L double precision :: AIN(10**6),ATIME(20) double complex :: AOUT(10**6) ------------------- CALL cFFTW(AIN,AOUT,N) Contains subroutine cFFTW(Ain,Aout,N) ! use libfftwf double precision in,ain dimension in(N),ain(10**6) double complex out,aout dimension out(N/2 + 1),aout(10**6) integer*8 plan integer I !DEC$ OBJCOMMENT LIB:'libfftw3.lib' DO I=1,N in(I)=AIN(I) END DO call dfftw_plan_dft_r2c_1d(plan,N,in,out,FFTW_ESTIMATE) call dfftw_execute_dft_r2c(plan, in, out) call dfftw_destroy_plan(plan) end subroutine cFFTW end program bFFTW [/bash]When I try to compile it with ifort, I get the message :
[bash]bFFTW.F90(4) : Error: Error in opening the compiled module file. Check INCLUDE paths. [LIBFFTW3] use libfftw3 --------^[/bash]
Can you help me either to add properly the libs in Visual Studio 2005 or to compile and link it with intel fortran 9.1?
I will comment that if the library is written in C and has lowercase names, you will need some set of declarations of the routines. I presume that's what's supposed to be in a libfftw3 module.
>> If that's so, then what prompted you to add a "use libfftw3" to your source?
Because, usually in Fortran, The USE statement is used to include an external library. Is there another way to do it? If, I comment the Use statement and let just this:
[bash]!DEC$ OBJCOMMENT LIB:'libfftw3.lib'[/bash]I get this error during the compilation:
[bash]bFFTW.obj : error LNK2019: unresolved external symbol _DFFTW_PLAN_DFT_R2C_1D ref erenced in function _MAIN__ bFFTW.obj : error LNK2019: unresolved external symbol _DFFTW_EXECUTE_DFT_R2C ref erenced in function _MAIN__ bFFTW.obj : error LNK2019: unresolved external symbol _DFFTW_DESTROY_PLAN refere nced in function _MAIN__ bfftw.exe : fatal error LNK1120: 3 unresolved externals[/bash]
How do I make Fortran understand the lower case subroutines names? That may explane the error above.
There are several approaches you can take, but let's start with the simplest. Add these lines in your declaration section:
!DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d
!DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_execute_dft_r2c" :: dfftw_execute_dft_r2c
!DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_destroy_plan" :: dfftw_destroy_plan
Now I don't know if these routines need anything else, such as passing some arguments by value. If so, that would require something more. You'll know that you have this issue if you get an access violation on a call.
I have tried this
[bash]Program bFFTW
!DEC$ OBJCOMMENT LIB:'libfftw3.lib' !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_execute_dft_r2c" :: dfftw_execute_dft_r2c !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_destroy_plan" :: dfftw_destroy_plan [/bash]
And I get this error:
[bash]bFFTW.F90(6) : Error: Only a function or subroutine subprogram may have the !DEC $ ATTRIBUTES directive DECORATE specifier. [DFFTW_PLAN_DFT_R2C_1D] !DEC$ ATTRIBUTES DECORATE, ALIAS:"dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d[/bash]
!DEC$ ATTRIBUTES ALIAS:"_dfftw_plan_dft_r2c_1d" :: dfftw_plan_dft_r2c_1d
!DEC$ ATTRIBUTES ALIAS:"_dfftw_execute_dft_r2c" :: dfftw_execute_dft_r2c
!DEC$ ATTRIBUTES ALIAS:"_dfftw_plan_destroy_plan" :: dfftw_destroy_plan
