- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I'm using VF in VS 2010 and when i'm trying to compile/build projects (.exe) with external libraries files i'm getting fatal error while linking.
fatal error LNK1120: 1 unresolved externals
XXXXXX build failed.
fatal error LNK1120: 1 unresolved XXXXXXXXXX build failed.I'm having this library already complied in the same output directory i have configured the project to wirte all its output files ?
any directions are appreciated.
링크가 복사됨
1 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Simply having a library in a certain place does not make the linker use it. There must be
(i) a reference to a symbol in the library (this is satisfied because the linker said "..unresolved..."),
AND
(ii) the linker must be told that the symbol is to be found in a certain library.
I suspect that (ii) has not been satisfied.
AND
