29277 Discussions
Exiting an OMP DO parallel loop due to detection of error condition in one thread
OP1
New Contributor III
IVF will not accept having a RETURN or EXITstatement inside a parallel DO OMP loop (it's not legal). I want to do the following:
!$OMP DO
... threads do some work in parallel
... if one thread detects an error condition (say, my algorithm does not converge fast enough), a signal should be sent to all threads to stop their calculations, and all should exit the loop.
!$OMP END DO
How can I achieve this?
Thanks!!
Olivier
jimdempseyatthecove
Oliver,
use a shared variable
logical :: ExitLoop
ExitLoop = .false.
!$OMP DO
IF(SomeLogicalErrorExpression) then
ExitLoop = .true.
exit
ENDIF
!$OMP END DO
Caution, to not use
ExitLoop = SomeLogicalErrorExpression
as this will/may unset one threads exit condition.
Jim Dempsey
OP1
New Contributor III
Oliver,
logical :: ExitLoop
ExitLoop = .false.
!$OMP DO
ExitLoop = .true.
exit
ENDIF
!$OMP END DO
Caution, to not use
Jim Dempsey
Jim,
You cannot have an EXIT statement inside a parallelized DO loop...
I am looking for a wayof signaling the threads to stop the (possibly) length calculations they're doing when one of them has encountered a condition that renders any further work useless.
Olivier
jimdempseyatthecove
Sorry about that, then plan B
[cpp]    logical :: DoExit
    integer :: i
    print *, 'Begin'
    DoExit = .false.
!$omp parallel do
    do i=1,1000
        if(DoExit) cycle
        print *, i
        if(iand(i, 15) .eq. 0) DoExit = .true.
    end do
!$omp end parallel do
    print *, 'End'
 Begin
           1
           2
           3
           4
           5
           6
           7
           8
           9
         501
          10
         502
          11
         503
          12
         504
          13
         505
          14
         506
          15
         507
          16
         508
 End
[/cpp]
I can see why GOTO out of the loop should be inhibited. EXIT should not be a problem excepting for potential BARRIER problems. The code above using CYCLE would have the same symptoms should barrier follow the CYCLE.
The BARRIER could be corrected (in implementation) where the EXIT implicitly decrements the number of threads in the team (seperated from the variable held for omp_get_num_threads()). Then the barrier can wait for the remaining number of threads.
Jim Dempsey
