Exporting/Sharing Code Coverage Results
Curran_K_
I have run Code Coverage and have obtained the results in the form of a HTML file on my C drive. I can easily read the results by opening the HTML file in a web browser but I want to know if there is a way of sharing these results with colleagues, as the files do not let me right click and export?
Thanks in Advance
jimdempseyatthecove
Try opening the HTML file in your web browser, selecting the text, copy, then paste into notepad or wordpad. SaveAs ...
Jim Dempsey
Steven_L_Intel1
Often you can select "Print to PDF" if you just want to share what you are seeing on the screen. This won't preserve links to source files, though.
Curran_K_
Thanks Guys,
I tried pasting into notepad but the highlighting colors generated from the code coverage tools do not copy, so that method doesn't work.
I can't find a 'Print to PDF' button so I have just resorted in sharing network drives.
jimdempseyatthecove
You can paste into Word (or WordPad). Then SaveAs to different format if you wish.
Why were you having problems with sharing the files?
Such as you could eMail them the html file, or copy to a shared folder.
Jim Dempsey
Steven_L_Intel1
There would not be a button - tell your browser to print and often you will find in the selection of "printers" a "Save to PDF" choice.
