Hi there,
the following example yields seg faults is complied uncommenting "trial a" and commenting "trail b", but works nicely if commented vice versa.
Module mod_type1 type :: type1 real, pointer :: p(:,:)=>null() contains Final :: Dealloc End type type1 contains Subroutine Dealloc(this) type(type1) :: this write(*,*) "I am here" Deallocate(this%p) End Subroutine Dealloc End Module mod_type1 program Test use mod_type1 real, allocatable, Target :: a(:,:) type(type1), allocatable :: b allocate(a(1000,1000)) !!@@@@@@@@@ !! trial a !allocate(b) !b%p=>a !Deallocate(b) !!@@@@@@@@@@ !! trial b allocate(b) allocate(b%p(1000,1000)) Deallocate(b) End program Test
The big thing is that one cannot ask whether a pointer is allocated or just associated. Otherwise one could make an if branch in "Dealloc" either nullifying or deallocating. From putting trial b into a loop I found that just putting a nullify statment int "Dealloc" will result in memory leak.
Am I missing something here??? Or does one has to live with the risk that the pointer may have been "abused" for memory allocation when writing the finalizer??
Karl
The language rules prohibit an attempt to deallocate an allocatable variable through a pointer (see final sentence of F2008 6.7.3.3p1).
It is not clear from your example what the design intent of your code is. Typically it should be clear at a point in your code which thing "owns" the target of a pointer.
See IanH's comment above on your design intent being unclear. With the use of a pointer component, you're venturing into territory that requires some thought and attention. Does your type really need to support the use cases indicated by both trial a and trial b? If your primary need is along the lines of your trial b, you may simply make the component of your type a variable with ALLOCATABLE attribute instead of a pointer. If you do want to do both, you would need to accept some responsibility and keep track of ownership of allocated memory yourself. A simple example is:
module m implicit none private type, public :: t private logical :: p_alloc = .false. integer, pointer, public :: p(:) => null() contains private final :: clean_t procedure, pass(this), public :: set_p end type t contains subroutine set_p( this, n ) class(t), intent(inout) :: this integer, intent(in) :: n !.. Local variables integer :: istat call clean_t( this ) allocate( this%p(n), stat=istat ) if ( istat == 0 ) then this%p_alloc = .true. end if return end subroutine set_p subroutine clean_t( this ) type(t), intent(inout) :: this print *, "clean_t invoked." if (this%p_alloc) then deallocate(this%p) end if this%p => null() this%p_alloc = .false. return end subroutine clean_t end module m
program p use m, only : t integer, parameter :: n = 1 integer, allocatable, target :: a(:) type(t), allocatable :: b !.. Trial A allocate( a(n) ) allocate(b) b%p => a deallocate(b) deallocate(a) !.. Trial B allocate(b) call b%set_p( n=n ) deallocate(b) stop end program p
Try the above example and see if you still get the segmentation fault and also run it through Valgrind and Intel Inspector, etc. and check for memory leaks.
Hi there,
Thanks for the reply. I can(have to) live with the responibility and had already code like the logical switch in mind. But I thought I was missing something.
However, your question was about the intent of of such code.
It is for instance usefull when doing linked list where the acutal list content is stored behind an (unlimited) polymorphic pointer. Such a list struture would look like
Module Mod_MMatrix Type :: MMatrix Real, Pointer :: tmp(:,:)=>null() contains Final :: Deallocate end type contains Subroutine SubDeallocate(this) Type(MMatrix) :: this if(allocated(this%tmp)) deallocate(this%tmp) End Subroutine end Module Mod_MMatrix Module LL Type ListElement Type(ListElement), Pointer :: previous=>null(), next=>null() Class(*), Pointer :: content=>null() End Type end Module LL
Making tmp allocatable would for some applications require copying huge amount of data, where as not allocating memory via the pointer would require additonal variables (more code) for other applications. And since the finalizer is invoked automatically when callling Deallocate(content) the segfault is guaranteed if one is not carefull.
Cheers
Module Mod_MMatrix Type :: MMatrix Real, Pointer :: tmp(:,:)=>null() contains Final :: Deallocate end type contains Subroutine SubDeallocate(this) Type(MMatrix) :: this if(allocated(this%tmp)) deallocate(this%tmp) End Subroutine end Module Mod_MMatrix Module LL Type ListElement Type(ListElement), Pointer :: previous=>null(), next=>null() Class(*), Pointer :: content=>null() End Type end Module LLMaking tmp allocatable would for some applications require copying huge amount of data, where as not allocating memory via the pointer would require additonal variables (more code) for other applications. And since the finalizer is invoked automatically when callling Deallocate(content) the segfault is guaranteed if one is not carefull.
You need to decide whether your list stores references to objects managed elsewhere, or whether the list stores references to objects that it owns, or whether the list stores the value of objects.
If the list is storing references to objects managed elsewhere, then it shouldn't be calling DEALLOCATE(content) - that's the job of whatever thing is supposed to be doing the management.
(Allocatables can be moved quite efficiently.)
In your original post, if your type1%p can be both directly allocated and pointed to => within the same program, then it would be advisable to also include a flag to indicate if the pointer were directly allocated or not. You might be able to discern this without an explicit flag if you have a separate means to determine if the array descriptor has the target attribute. IOW when target, do not deallocate and nullify.
Jim Dempsey
may.ka wrote:
.. I can(have to) live with the responibility and had already code like the logical switch in mind. But I thought I was missing something.
It is for instance usefull when doing linked list where the acutal list content is stored behind an (unlimited) polymorphic pointer. Such a list struture would look like ..
Cheers
Sure, but you have sufficient options in terms of class design in standard Fortran to work with such linked lists. It's unclear from your design why tmp component of MMatrix type needs to have pointer attribute nor the content component of your ListElement. Among other things, you can also consider an abstract data type that does all the mechanics of working with a doubly linked list and a concrete implementation of such an abstract type for a matrix element can have a data component of allocatable attribute. Memory management and avoiding leaks, etc. becomes much easier then.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
