FORTRAN 77 NEQNF IMSL Solver, 2 variables, 6 equations.
Mustafa_U_
Hello!
I am trying to use NEQNF to solve a system of 6 non linear equations. I need to determine 2 variables to solve my system. According to description i need to define "N" which is the length of "X"(variables) AND "F"(equations).
Does this mean that i can use this solver only if X=F? Because N is defindes as an integer in the example given below in the description.
Or can i define N as a vector? How does declaration of N supposed to look like in this case?
And i have some general questions about the solver:
What happens if there is more than one solution for my system?
I can define XGUESS. Will this guess only be taken for the first step?
Fortran 77, Visual Studio 2008 Pro
Thanks in advance,
ikkebins!
mecej4
The number of equations must equal the number of unknowns, if you wish to use NEQNF. To solve over-determined nonlinear equations, consider routines such as UNLSF (IMSL) and ?TRNLSP (MKL).
"X = F" makes no sense. For example, X could be coordinates expressed in meters, and F could be made up of force components. However, it would be correct to say that size(X) = size(F).
mecej4
Mustafa_U_
Thank you very much for your reply!!!
I was looking for a solver like this, but somehow couldn´t find it.
size(X) = size(F): Yes that was what i meant, but guess i was very imprecise there :)
DavidWhite
Valued Contributor II
Mustafa,
Elaborating on the comment that the number of equations must equal the number of variables to use NEQNF - this requirement is required mathematically.  If the number of equations is not equal to the number of variables, then you can only solve several of the equations at a time to get a solution.  Solving any other pair of equations may give you a different solution.  It is unlikely that the solution of all the equations at the same time will give the same unique solution.
NEQN = NVARS is a mathematical requirement, not for any particular solver.
David
