Finalization of variables of extended type
sstamat
There seems to be a bug in ifort Version 13.0.1.117 regarding the finalization of allocated variables of extended type.
I don't think it has been reported in the forum.
Consider the following code:
[fortran]
MODULE modu
  TYPE :: a_t
   CONTAINS
     FINAL :: d_a
  END TYPE a_t
  TYPE, EXTENDS (a_t) :: b_t
   CONTAINS
     FINAL :: d_b
  END TYPE b_t
CONTAINS
  SUBROUTINE d_a(this)
    TYPE (a_t) :: this
    PRINT *, "finalize a"
  END SUBROUTINE d_a
  SUBROUTINE d_b(this)
    TYPE (b_t) :: this
    PRINT *, "finalize b"
  END SUBROUTINE d_b
END MODULE modu
PROGRAM test
    USE modu
    PRINT *, " sub1 "
    CALL sub1()
    PRINT *, " sub2 "
    CALL sub2()
    PRINT *, " sub3 "
    CALL sub3()
CONTAINS
  SUBROUTINE sub1()
    TYPE (b_t) :: c
  END SUBROUTINE sub1
  SUBROUTINE sub2()
    CLASS (a_t), ALLOCATABLE :: c
    ALLOCATE(b_t :: c)
  END SUBROUTINE sub2
  SUBROUTINE sub3()
    ALLOCATE(b_t :: c)
    DEALLOCATE(c)
    PRINT *, "deallocated"
  END SUBROUTINE sub3
END PROGRAM test
[/fortran]
The finalization process for the variables in each of the subroutines sub1, sub2, sub3 is different (although it shouldn't be):
The variable in sub1 is finalized correctly (the final routine for the extended type is called, which, in turn, calls the final routine of the base type).
The variable in sub2 is finalized by calling the final routine of the base type (the declared type) only.
The variable in sub3 is finalized when deallocated explicitly by calling twice (!) the final routine of the base type. It is finalized again (although it shouldn't) at the end of the subroutine, by calling once the final routine of the base type.
Steven_L_Intel1
Thanks, we'll take a look.
