I recently purchased a new computer with Windows XT. I have several mixed programs that I want to revise, using Compaq Visual Fortran v 6.6.C and MASM 6.15. Existing programs use DOS Interrupt 21h to write to disk and printer, but I cannot get recompiled programs to do so. I get the following error:
forrtl: severe [157] Program Exception - access violation
As I said, existing programs run without any problem, but I cannot get new versions of these same programs to work.
I even tried to call FORTRAN routines from the assembler routines, and can get the file to open, but not to write.
Does anyone have any suggestions?
Access to DOS interrupt functions via an assembler routine with a Fortran interface was easy and common using MS (and possibly other) 16-bit compilers. I did this for years with MSF5.1, and thereby extended my Fortran programs to almost any function, with excellent performance. This interrupt function no longer exists within 32-bit Windows (NT, 2K, XP),but rather is simulated as part of Win32 support of a "virtual" DOS environment for 16-bit "legacy" programs; it isn't available at all for native 32-bit programs such as are produced with CVF and IVF.
If you want your Fortran programs to have directaccess to low-level functions, the way to do this in a Win32 environment is to use Win32 API calls, which provide a richer and vastly more capable access to all aspects ofopsys functionality (also more complex: there were some 60 sub-flavors of Int21H, but there areabout 4000 Win32 API functions in the basic set). This restrictsprograms to Win32 systems only, but can also provide vast improvements overFortran-only coding. For example, replacing Fortran file i/o statements with Win32 API calls provides much greater versatility and probably 10x speed improvement. I can provide sample Fortran-Win32 file i/o code on request (pcurtis@kiltel.com).
Topic Options
