Fortran Dynamic Allocation Array
Hadi_S_
Hi
the problem is that How can i increase a (Fortran) allocated array size in a program?
in program like this:
real(8), allocatable, dimension(:) :: x
! programs body
N=100
allocate(x(N))
N=150
allocate(x(N)) ! but this is an error
there is two approach
First: using move_alloc
Second: using x=[x,(x(1),i=1,j-size(x))]
but x can be a class type array in bellow program you can see usage of two approaches in two loops.
I compare every approach for time cost and see second takes more time.
as Steve point that: in 2nd approach because x is used on both sides of the assignment, the compiler has to create a temporary for the array constructor before assigning to the left side, thus two copies. I don't see any good way to avoid a copy as it's very unlikely that the space after the existing array is unallocated. You can avoid making two copies, though, with suitable use of MOVE_ALLOC and initializing only the expanded elements.
!$ cat
program realloc
use iso_fortran_env, only : real64
implicit none
integer :: i,N,j
integer, parameter :: wp=real64
type math
    real(wp) :: x1
    real(wp) :: y1
end type
type(math), allocatable, dimension(:) :: h, temp
N=10
allocate(h(N))
h(:)%x1 = 1.
h(:)%y1 = 2.
do j=N, 100000 ! this loop takes 110 s (using GNU FORTRAN)
    allocate(temp(j))
    temp(1:size(h)) = h
    call move_alloc(temp, h)
    h(:)%x1 = 1.
    h(:)%y1 = 2.
    !print *,"size(h)=",size(h)
end do
do j=N, 100000 ! this loop takes 160 s (using GNU FORTRAN)
    h = [h,(h(1),i=1,j-size(h))]
    h(:)%x1 = 1.
    h(:)%y1 = 2.
end do
end program
so question: Intel(R) Visual Fortran Compiler XE 13.1.0.149 can run second approach but the dimension does not increase without any error.
and second approach is not really suitable? is really  move_alloc the best way? does it works using pointer and somethings?
Arjen_Markus
You need to specify the option /assume:realloc_lhs, as otherwise the automatic reallocation on assignment does not work
FortranFan
Look into compiler options of /assume:realloc_lhs as well as /standard-semantics (a more expanded option set that includes realloc_lhs) closely and see what matches closely with your needs.
Note the use of MOVE_ALLOC can give a coder better control in resizing arrays (both increasing as well as decreasing the size) and allow the placement of existing values as desired in the new array with a single copy operation.
