Fortran I/O functions
LRaim
A trip around Fortran I/O functions.
A Fortran application, launched by a C++ driver, writes a stream file which is later processed by the C++ application.
Now to add a backup feature, the fortran application at a certain point should:
1) find the actual position of the file (INQUIRE   POS=ipos1)
2)  write additional data, close and copy the file.
3) reopen the file and reposition at ipos1, for continuing the execution.
I am unable to find a fortran statement/specifier to restart writing data at ipos1.
Mark_Lewy
Valued Contributor I
You can use
write(unit, pos = ipos) stuff
with stream I/O. See Metcalf, Reid & Cohen Modern Fortran Explained 10.16.
jimdempseyatthecove
open output file
open copy file//sequence number
loop:
  write to output file
  write to copy file
  if(time to close copy file) then
    write additional stuff to copy file
    close copy file
    bump sequence number
  end if
end loop
Jim Dempsey
