Fortran Preprocessor Definition Failed in Makefile
danielsue
Dear All,
I have a cross-platform parallel program developed under windows, windows-cygwin and linux.
When use VS2010 to invoke the FPP and set the preprocessor definitions to "WINDOWS", the code can be compiled and works fine (result 1). But when use windows-cygwin, the Preprocessor Definition "CYGWIN" can not be recognized (result 2), but the code can be compiled to executable as well.
Maybe the configure in makefile is not corrected (It works fine if I have no preprocessor definition). I am not so familar with makefile's format.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Result!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Result 1:
Hello World
Solved in WINDOWS
Result 2:
Hello World
Unknow
!!!!!!!!!!!!!!!!!!!!!!!!!!Sample Codes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!Main
program Main
    use Solver
    implicit none
    ! Variables
    ! Body of Main
    print *, 'Hello World'
    call Solve
end program Main
!!Module
Module Solver
    implicit none
#ifdef CYGWIN
#include <finclude/petscsys.h>
#include <finclude/petscvec.h>
#include <finclude/petscmat.h>
#include <finclude/petscpc.h>
#include <finclude/petscksp.h>
#include <finclude/petscvec.h90>
#include <finclude/petscmat.h90>
#include <finclude/petscksp.h90>
#include <finclude/petscpc.h90>
#endif
contains
subroutine Solve()
    implicit none
#ifdef WINDOWS
    write(*,*) "Solved in WINDOWS"
#elif CYGWIN
    write(*,*) "Solved in CYGWIN"
#else
    write(*,*) "Unknow"
#endif
end subroutine Solve
end Module Solver
!!Makefile
# Makefile
include ${PETSC_DIR}/conf/variables
include ${PETSC_DIR}/conf/rules
#FC = ifort
MODEL =../Main/
# Additional flags that may be required by the compiler ...
# DFCFLAG = -em  # When using Cray Fortran compiler
#DFCFLAG =
FPPFLAGS = -fpp -DCYGWIN
# Additional libraries that may be required by the linker ...
# DLIB = -lmetis  # When METIS/ParMETIS are built or installed separately from PETSc
# DLIB = C:/cygwin/packages/metis-5.0.2/build/windows/libmetis/Release/libmetis.lib
SOURCES = $(MODEL)Solver.o    \
    $(MODEL)Main.o
all: $(SOURCES) chkopts
    -${FLINKER} $(FPPFLAGS) -o Main $(SOURCES) ${PETSC_LIB} ${DLIB}
    ${RM} $(MODEL)*.o *.mod
mecej4
I see only a part of the picture, but it strikes me that the use of $(FPPFLAGS) in the linker command line is neither required nor has any effect. Rather, -fpp and -DCYGWIN have to be used at the time that the .o files are being produced by compiling the sources. What are the implicit rules, in your setup, that are in effect for producing .o files from the sources?
danielsue
Thanks for your quick reply. I use makefile to build the project, as follows: -------------------- include ${PETSC_DIR}/conf/variables include ${PETSC_DIR}/conf/rules MODEL =../Main/ FPPFLAGS = -fpp -DCYGWIN SOURCES = $(MODEL)Solver.o \ $(MODEL)Main.o all: $(SOURCES) chkopts -${FLINKER} $(FPPFLAGS) -o Main $(SOURCES) ${PETSC_LIB} ${DLIB} ${RM} $(MODEL)*.o *.mod -------------------- The problem is: $(FPPFLAGS) does not take effect in the makefile.
danielsue
Thanks to the PETSc-maint. Problem solved. Rename the sourcefiles to use .F90 suffix and remove '-fpp' from FPPFLAGS.
danielsue
Thanks to you all.
