Fortran and C++ working together
Katarina_R_
I want to have Fortran code that will call some functions in C++. The thing is I want to create arrays of objects, some variables and I want C++ code to keep running after Fortran call. Basically I need something like this. Fortran calls C++ function that reads numbers from file and save it in a object variable, after that Fortran sleeps for a while and calls C++ function and gets the saved numbers. So I need to call C++ once to save some data, then call it again later on and work with the data that was saved. I need data in objects. I've read about external variables in Fortran and I saw that it can work with C++ through subroutines but I need a lot of objects in C++ code and don't want to store values in Fortran too. I work in VisualStudio.
Can this be done?
PaulF_IntelCorp
Katarina -- your thread was posted in the wrong forum. I'm moving it to a forum that I believe can help.
FortranFan
@katarina_ralevic,
Just for starters, take a look at this thread, particularly message #12 where a small but complete working example of C++ main working with a Fortran 'library' is shown:
https://software.intel.com/en-us/node/697150#comment-form
With the above thread as background, if you can provide specific details of your need - better yet, take a shot at some coding and post any difficulties here - you can get a lot more help.
Good luck,
Katarina_R_
@FortranFan
I have a simple question. I've made C++ static library and called it something.lib and I tried calling it from another C++ program to see if it works and it works fine. Then I've tried to call it from Fortran and I'm not sure should I write include or use in order to do that. And how exactly to write that call, I have a compiler problem when I write use something.lib it says that compiler can't find .mod files and when i write include  'something' it says cannot open include file 'something'.
jimdempseyatthecove
C/C++/?? libraries are not module. When Fortran calls such a library you must declare the subroutine/function using an interface block. However, note that you will also (usually) require a BIND C or !DIR$ ATTRIBUTE to specify the calling convention. The normal procedure to to use C calling convention as opposed to C++.
Check the IVF documentation under:
interoperability with C
   Standard Fortran and C Interoperability
Jim Dempsey
FortranFan
Katarina R. wrote:
@FortranFan
@Katarina R.,
Shown below is a simple but reasonably complete example, please note your C++ functions and library will be "external" to Fortran, so you would need to define those somewhere, preferably provide explicit interfaces (C type of function prototypes) in a Fortran module and inform the linker about the static library.  Attached zip file has the Visual Studio solution and project files for this; note it was created using VS 2013.
As suggested by Jim Dempsey, using the standard facilities in Fortran for interoperability with C may work out best for you; please note the companion C processor becomes the common platform for C++ and Fortran to interoperate.
Hope this helps,
#include <iostream>
using namespace std;
extern "C" {
   // Prototype for a function with extern attribute
   int cpp_foo(char *string, int i, double d[], size_t size_d, void *add_d);
   cout << "In cpp_foo: " << endl;
   cout << string << endl;
   cout << "i = " << i << endl;
   cout << "d = " << endl;
   for (size_t j = 0; j < size_d; j++)
      cout << "[" << j << "] = " << d << endl;
   cout << "address of d: = " << add_d << endl;
   return(0);
module m
   use, intrinsic :: iso_c_binding, only : c_int, c_char, c_double, c_size_t, c_ptr, c_loc, c_null_char
   implicit none
   private
   interface
      function cpp_foo(string, i, d, size_d, m) result( iret) bind(C, name="cpp_foo")
         import :: c_int, c_char, c_double, c_size_t, c_ptr
         implicit none
         !.. Argument list
         character(kind=c_char,len=1)  :: string(*)
         integer(kind=c_int), value    :: i
         real(kind=c_double)           :: d(*)
         integer(kind=c_size_t), value :: size_d
         type(c_ptr), value            :: m
         !.. return value
         integer(c_int) :: iret
      end function cpp_foo
   end interface
   public :: cpp_foo
end module m
program p
   use m, only : cpp_foo
   implicit none
   character(kind=c_char,len=:), allocatable :: msg
   integer(kind=c_int) :: i
   real(c_double), target :: d(10)
   integer(kind=c_size_t) :: size_d
   type(c_ptr) :: add_d
   integer(kind=c_int) :: iret
   msg = c_char_"Hello World!" // c_null_char
   d = [( real(i, kind=kind(d)), i = 1, size(d) )]
   size_d = int( size(d), kind=kind(size_d) )
   i = 42
   add_d = c_loc( d )
   iret = cpp_foo( msg, i, d, size_d, add_d )
   print *, "cpp_foo returns ", iret
   stop
end program p
Upon execution, you should get:
In cpp_foo:
Hello World!
i = 42
d =
[0] = 1
[1] = 2
[2] = 3
[3] = 4
[4] = 5
[5] = 6
[6] = 7
[7] = 8
[8] = 9
[9] = 10
address of d: = 000000000021F9F0
 cpp_foo returns  0
Press any key to continue . . .
Katarina_R_
@FortranFan and @jimdempseyatthecove
Thank you both so much. I've tried the example and it works, the last problem I have is that Fortran program that I have is .for and this example is .f90. Is there some way that are not modules to connect C++ and Fortran since .for  doesn't support modules? Or is it possible that my .for program calls .f90 and then I can leave everything like it is in the example?
Arjen_Markus
You misunderstand the meaning of the two extensions. They represent different forms of the source code, not different capabilities. .for (or .f) is typically used for "fixed form" source and .f90 is used for "free form". So you can use modules in a file with the extension .for, as you can use all other features of the Fortran language.
Katarina_R_
I've already tried to just write this example in .for and it's not working. I've read about "fixed form" files and conventions for writing them and I guess made some mistake since I'm new to Fortran.
Arjen_Markus
Can you post your code and elaborate on what is not working? Compiler errors?
FortranFan
Katarina R. wrote:
.. the last problem I have is that Fortran program that I have is .for and this example is .f90. Is there some way that are not modules to connect C++ and Fortran since .for  doesn't support modules? Or is it possible that my .for program calls .f90 and then I can leave everything like it is in the example?
@Katarina R.,
Now you're asking basic questions related to FORTRAN and Fortran: I suggest you go through sources like the one below fully:
http://fortranwiki.org/fortran/show/HomePage
