29280 Discussions
Fortran projects working in Parallel Studio XE 2020 does not open in one API HPC 2021.4
Mike_Z_
MS Visual Studio 2019 doesn't open source code. What's the problem?
Devorah_H_Intel
I checked on VS 2019 (v 16.11.3) + oneAPI 2021.4.0 - no problem with opening PSXE projects.
Try the following:
Right click on the project name in Solution Explorer and click Reload Project
Devorah_H_Intel
Try the following:
Mike_Z_
Thanks a lot! It helps!
VS2019 16.11.4
JohnNichols
Valued Contributor III
16.11.4 is the latest, it caused my problem.  The simple fix does not work.
Devorah_H_Intel
That is a different issue.
Supported versions are:
VS 2019 16.10.3 - full testing
VS 2019 16.11.2 - limited manual
https://software.intel.com/content/www/us/en/develop/articles/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html
In my testing 16.11.3 works fine with older Fortran projects.
I do not expect 16.11.4 to be fully supported until next Compiler release.
JohnNichols
Thank you.  (Sometimes the blood drips onto the carpet.)
I should not ask, but when would you expect .5?
