29434 Discussions
Fortran to C and Back, the saga continues
rforehan
My poor old brain has turned to jello trying to set up the interface for the following C++ routine:
extern "C" float* getFrequencies(int &n);
The function returns a pointer to anarray of floats and sets n to the number of values in the array.
I placed the function interface into a module as follows:
MODULEMyModule
USE ISO_C_BINDING
IMPLICIT NONE
FUNCTION getFrequency(n)
interface
function getFrequencies(n)
use ISO_C_BINDING
real(C_FLOAT), dimension(:), pointer :: getFrequencies
!DEC$ ATTRIBUTES C,REFERENCE,DECORATE, &
ALIAS:"getFrequencies" :: getFrequencies
integer(C_INT), intent(INOUT) :: n
!DEC$ ATTRIBUTES REFERENCE :: n
end function
end interface
real, dimension(:), pointer :: getFrequency
integer n
getFrequency => getFrequencies(n)
END FUNCTION
END MODULE
Then I attempted to use the function as follows:
real, dimension(:), pointer :: frequencies
integer numPts
frequencies => getFrequency(numPts);
I was guessing that I had to turn the float pointer into a dimensioned array in Fortran, but I'm missing some concept in understanding how to go about doing it.
Thanks for any help in retraining an old dog,
Dick
The C function doesn't return an array, it returns a pointer, so that's how you'll have to declare it. Try this:
MODULE MyModule
USE ISO_C_BINDING
IMPLICIT NONE
contains
interface
function getFrequencies(n) bind(C,name="_getFrequencies")
import
type(C_PTR) :: getFrequencies
end function
end interface
integer n
call C_F_PTR(getFrequencies(n), getFrequency, )
END FUNCTION
END MODULE
You'll have to remove the leading underscore from the name= when we fix the compiler bug in this regard.
rforehan
Steve,
I'm using version 10.0.025 of the compiler. Has the bug been fixed in it? I had to remove that leading "_"after name= to avoid link error Also add to change to C_F_POINTER.
Aside from that, it worked great.
I'm still trying to fully understand the POINTER attribute. It seems more like an access type in Ada as opposed to a C pointer. Does the normal assignment operator "=" automatically dereference the variable, i.e.,ptr A = ptr B sets the value pointed to by A to the value pointed to by B instead of setting A to point to the same address as B, whereasthe pointer assignmentoperator "=>"(ptr A => ptr B) sets ptr A to point to the same address as ptr B? Man, that looks like typo hell just waiting to grab you.
Thanks again for your help,
Dick
Sorry about the C_F_PTR - that was my error.
Actually, the bug I mentioned was introduced in 10.0.026 or thereabouts and is not fixed yet. It was due to a misunderstanding.
POINTER is not like C pointers. Automatic dereferencing does occur depending on the context. You have the distinction correct.
