Function return value in IF STATEMENT
Ibrahim_K_
Friends;
This is probably silly question: why does the first if statement gives Compilation error #6385 while the second one compiles.
C
C     LOGICAL :: TEST
C
      IF(COMPASX(RUNTYP,STAT))    GOTO 91
C
      TEST=COMPASX(RUNTYP,STAT)
      IF(TEST)                    GOTO 91
C
The function COMPASX is defined as follows:
      LOGICAL FUNCTION COMPASX(AONE,ATWO)
      IMPLICIT INTEGER (I-N)
      IMPLICIT REAL (A-H,O-Z)
      !LOGICAL::COMPAS
      CHARACTER,INTENT(IN) :: AONE(4), ATWO(4)
      ! standard Fortran IV convention
      DO I=1,4
          IF( (LLE(AONE(I),ATWO(I)) .XOR. LLE(ATWO(I),AONE(I))) ) THEN
              COMPASX=.FALSE.
              RETURN
          END IF
      END DO
      COMPASX=.TRUE.
      RETURN
      END FUNCTION COMPASX
By the way, could somebody suggest a better way to compare two character arrays in FORTRAN?
Regards;
I. Konuk
andrew_4619
You have more than one problem but I think the first one is that the type of function compasx is not known where it is called. If compasx was in a module or there was an explicit interface that would not be the case. Adding logical, external :: compasx in the calling routine would be helpful to the compiler. The types of your call parameters also need examination.
John_Campbell
New Contributor II
The following code fits with your coding approach and is valid Fortran:
  DO I=1,4
    IF ( AONE(I) .EQ. ATWO(I) ) CYCLE
    COMPASX=.FALSE.
    RETURN
  END DO
  COMPASX=.TRUE.
  RETURN
I would suggest that if there is confusion with the order or evaluation of functions in an IF statement (more complex than presented), then your second approach is to be preferred as it removes any ambiguity of order or evaluation when reading the code.
jimdempseyatthecove
John,
#3 is not always correct. Depending on character set, one could be defined as having two characters that are lexically equal yet numerically different.
If numerically equal is sufficient, then consider:
  IMPLICIT NONE
  INTEGER(4) :: MOLD
  COMPASX = (TRANSFER(AONE,MOLD) == TRANSFER(ATWO,MOLD))
  RETURN
Should that function be placed in a module, then chances of inlining are good.
Jim Dempsey
Ibrahim_K_
Dear Friends:
Thank you for the clear explanation (I kind of guessed it) and helpful suggestions. I will use the approach closer to mine but much cleaner.
Regards;
I. Konuk
jimdempseyatthecove
FWIW>>Depending on character set, one could be defined as having two characters that are lexically equal yet numerically different.
As an example: 'a' and 'A' could have the same collating sequence (depending on the selected collating sequence).
Jim Dempsey
