29276 讨论
Funny symbols in "include" file (maybe library interface specs?)
dposnersbcglobal_net
457 次查看
Forgive me, the last time I wrote fortran code I used punch cards. I'm trying to compile a modeling system from the energy department (NEMS) and the .f file has an "include" file and the include file has lines like the following:
INTEGER*4 FUNCTION WFMPSOU ( ACTFILE, ACTPROB, FILENAME, &
DECJABNEm IBECIEF )
and
integer*4 function OMLXPRSsetintcontrol &
[STDCALL, ALIAS:'_OMLXPRSgetintcontrol@8'] &
(index, ivalue)
I'm guessing this has something to do with interfacing to libraries (OML is a library) but my Fortran compiler hasn't any idea what to make of these things. Can anyone give me a clue or a pointer?
0 项奖励
2 回复数
TimP
名誉分销商 III
457 次查看
(index, ivalue)
This one looks like a clumsy way of using an obsolete interface to 32-bit Microsoft C, so you would want to change to something more standard.
0 项奖励
Steven_L_Intel1
457 次查看
Which Fortran compiler is yours? Intel Fortran accepts that syntax, which is an old Microsoft extension. However, as Tim correctly notes, this bit is written specifically for Windows, so if you want to use it on Linux, you'll need to make changes.
0 项奖励
回复
