29252 Discussions
Generic procedure reference has two or more specific procedure with the same type/rank/keyword signature
OP1
Nouveau contributeur III
461 Visites
I would like to know if it is possible to have a generic function returning values of different types, depending on the value it is assigned to.
For instance, the following program will trigger an error with IVF 10.1 . It's obvious I could transform these functions into subroutines (in which case it would work), but I thought the compiler would recognize the type of variable the function result is passed to in the main program.
Olivier
[fortran]PROGRAM MAIN
    USE MODULE_INTERFACES
    IMPLICIT NONE
    INTEGER I
    REAL(8) R
    I = GENERIC_FUNCTION(1)
    R = GENERIC_FUNCTION(1)
    WRITE(*,*) 'I = ',I
    WRITE(*,*) 'R = ',R
END PROGRAM MAIN
MODULE MODULE_INTERFACES
    IMPLICIT NONE
    INTERFACE GENERIC_FUNCTION
        INTEGER FUNCTION IFUN(I)
            INTEGER,INTENT(IN) :: I
        END FUNCTION IFUN
        REAL(8) FUNCTION RFUN(I)
        END FUNCTION RFUN
    END INTERFACE GENERIC_FUNCTION
END MODULE MODULE_INTERFACES
    IMPLICIT NONE
    IFUN = I
END FUNCTION IFUN
    IMPLICIT NONE
    RFUN = COS(DBLE(I))
END FUNCTION RFUN
[/fortran]
0 Compliments
3 Réponses
TimP
Contributeur émérite III
461 Visites
The Fortran standard specifies that the selection is made by examining the argument list without reference to the data type to which a function result is assigned. The compiler would be perfectly happy to convert either type of function result to match the assignment, but is required by the standard to diagnose the duplicate generic function argument lists.
0 Compliments
IDZ_A_Intel
Employé
461 Visites
Because functions are meant for use in expressions, things could get rather confusing if selection on the "use of the function result" was considered. Consider:
[fortran]real :: r(10)   ! different kind and rank
r = 2 + generic_funtion(1)  ! mixed types in expression
[/fortran]
[bash]write (*,*) generic_funtion(1)
[/bash]
[fortran]interface gen_sub
  module procedure gen_sub_i  ! takes an integer
  module procedure gen_sub_r  ! takes a real
end interface gen_sub
call gen_sub(generic_function(1))
[/fortran]
0 Compliments
OP1
461 Visites
Yes, that is true. Using a generic subroutine to achieve this makes a lot more sense. I have to say though that I have never really liked the mixed arguments feature in expressions (that and the fact that IMPLICIT NONE is optional...). I suppose these are legacy oddities which will persist in the Fortranstandard for decades to come :) ...
Thanks for your answers!
Olivier
0 Compliments
Répondre
