IF(ISW .eq. 1 )then ID=0 M=0 L=NDF !------------------------------------------------------------------------------------------------------- ! ! ! !------------------------------------------------------------------------------------------------------ 903 JJ=J1-1 IF(JJ .gt. 0) then 905 DO 910 J=1,JJ DO 910 K=1,6 910 ID = ID + JTYPE(J,K) endif 912 DO 965 IC=1,6 IF(JTYPE(J1,IC) .lt. 1)then 915 DO 916 N=1,NLS 916 ASAT(M + IC,N) = 0.0 else 920 DO 925 N=1,NLS 925 ASAT(M+IC,N)=GK(ID+1,L+N) ID=ID+1 endif 965 end do IF(M .lt. 1) then 980 M=6 J3=J1 J1=J2 ID=0 GO TO 903 endif !------------------------------------------------------------------------------------------------------- ! ! ! !--------------------------------------------------------------------------------------------------- 990 DO 1100 II=1,6 DO 1100 J=1,NLS SR(II,J)=0. DO 1100 K=1,12 1100 SR(II,J)=SR(II,J)+SAT(II,K)*ASAT(K,J) !Write(*,1010)I if(i .eq. 1) then Write(*,1011)LSN(I) Write(sw,1011)LSN(I) endif DO 1020 J=1,NLS write(*,1030)i,(SR(II,J),II=1,6),(-(SR(2,j)+SR(3,j))/Length(I)),(-(SR(4,j)+SR(4,j))/Length(I)) 1020 write(sw,1030)i,(SR(II,J),II=1,6),(-(SR(2,j)+SR(3,j))/Length(I)),(-(SR(4,j)+SR(4,j))/Length(I)) !pause 1030 FORMAT(I4, 5x,1X,5(F11.4,2x),F10.4,1x, F10.4, 1x, F10.4) N=4 J=12 endif
I have been getting rid of all the arithmetic goto's inside this "old" Fortran -- from the 1973 book from Harrison -- I am blowed if I can see an elegant method to get rid of the goto 903. I have had several shots at it and I end up always breaking the program.
Any ideas would be appreciated - I was thinking a do while on M?
John Nichols wrote:
.. I have been getting rid of all the arithmetic goto's inside this "old" Fortran -- from the 1973 book from Harrison -- I am blowed if I can see an elegant method to get rid of the goto 903. I have had several shots at it and I end up always breaking the program.
If your arrays are not too large for you to consider vectorization/parallelization options, you can consider starting from something as shown below: naturally UNTESTED and with the two "magic numbers" of 6 and 12 replaced by named constants of MN_6 and MN_12 respectively.
if ( ISW == 1 ) then do K = 1, 2 ID = 0 M = (K-1)*MN_6 if ( J1 > 1 ) then ID = sum( JTYPE( 1:J1-1, 1:MN_6) ) end if do IC = 1, MN_6 if ( JTYPE(J1,IC) < 1 ) then ASAT(M+IC,1:NLS) = 0.0 else ASAT(M+IC,1:NLS) = GK(ID+1,NDF+1:NDF+NLS) ID = ID + 1 end if end do if ( K == 2) then J3 = J1 J1 = J2 end if end do SR(1:MN_6,1:NLS) = matmul( SAT(1:MN_6,1:MN_12), ASAT(1:MN_12,1:NLS) ) if ( i == 1 ) then write(*,1011) LSN(I) write(sw,1011) LSN(I) end if do J = 1, NLS write(*,1030) i,(SR(II,J),II=1,6),(-(SR(2,j)+SR(3,j))/Length(I)),(-(SR(4,j)+SR(4,j))/Length(I)) write(sw,1030)i,(SR(II,J),II=1,6),(-(SR(2,j)+SR(3,j))/Length(I)),(-(SR(4,j)+SR(4,j))/Length(I)) 1030 format(I4, 5x,1X,5(F11.4,2x),F10.4,1x, F10.4, 1x, F10.4) end do !pause N=4 J=12 end if
P.S.> Code edited: added matmul in place of dot_product in the assignment statement for SR.
連結已複製
I second andrew_4619's advice. In fact, ditch the old spaghetti and rewrite the whole code, if you want modern style and understand the algorithm completely. If you tinker with old code with lots of GOTO and IF statements, it is very easy to introduce new bugs, unless you use a proven code polisher.
One idea: lines 12-34 could be replaced with (please double check; not listening to my own advice here!):
do do j=1,j1-1 id=id+sum(jtype(j,1:6)) end do do ic=1,6 if (jtype(j1,ic) < 1) then asat(m+ic,1:nls) = 0 else asat(m+ic,1:nls)=gk(id+1,l+(1:nls)) id=id+1 endif end do if (m >= 1) exit m=6 j3=j1 j1=j2 id=0 end do
Dear All:
I cannot help tinkering - I am an engineer. You are not on this forum unless you enjoy some form of pain - daily.
I understand the algorithm very well, studied it for 3 year at Uni and I can do it using an plain inverter, but this program came with a nice set of pictures in the book and some samples. It will be rewritten in entirely new form by experts, I merely hack a crude path in the wilderness to see what is possible. An eigensolver has been fitted to the rear end and it is providing some light relief. MKL Feast is excellent --
Thanks for the help I will now try them.
John
You could write that loop beginning at label 903 as
do m=0,6,6
ID=0
end do
I also have a personal preference for sanitizing code this way. Why make it unnecessarily obscure?
The if(jj > 0) was made redundant by F77, although F66 didn't define that case without the explicit comparison.
MATMUL is the rank 2 equivalent of dot_product.
Matmul worked and I got the standard answers as before so the replacement worked - again thanks. Still have to do a full check - but it appears to work.
I would post the code - but a very expensive lawyer explained IP to me and made me aware of the dangers of publishing code that has a value
Interestingly the Eigen solver does not give exact multiples for the harmonics -- off by a little bit. The MKL solver is way faster than the eigensolvers in the structures program and it gives the vectors which really help.
John
