Comunicados
29298 Discussões
Help: Is there any software or program to test the peak memory used by a program?
Zhanghong_T_
Novato
810 Visualizações
Hi all,
I am looking for a software to record the peak memory (including virtual memory) used by a program when running it. Often the program runs for a long time and it is boring to watch the memory changes in Task Manager of Windows. Can anyone tell me how to record it automatically?
Zhanghong Tang
4 Respostas
greldak
Principiante
810 Visualizações
Have you tried selecting the Peak Memory Usage checkbox on theView->Select Columns page?
Paul_Curtis
Contribuidor valorado I
810 Visualizações
The Win32 API function GlobalMemoryStatus returns the total available physical memory as well as the instantaneous available memory, which gives a rough idea of how much memory your program is using (of course, the memory-in-use value reflects all operating processes, not just your program).
Zhanghong_T_
Novato
810 Visualizações
Thank both of you very much!
Mitchell, can you tell me whether the actual peak memory used by a program includes the Virtual Memory listed in Task Manager?
Paul-Curtis, do you mean that the API function can't calculate the memory only used by my program?
Zhanghong Tang
g_f_thomas
Principiante
810 Visualizações
The Win API can calculate the memory used by your program but you'll have to know the process handle. After the creation of your process an external inquirer can retrieve the process handle and hence its specific memory usage. The prcview v 3.7.3.1 app freely available at http://www.prcview.com does this and some.
HTH,
Gerry T.
Responder
