29386 Discussions
Hi.. I've a problem with my fortran project. It dosen't create a .exe and the errors are:...
DEBORA_P_
Error    18     error LNK2019: unresolved external symbol _COMPR_PT@172 referenced in function _MAIN__    main_curve_unita.obj
Error    19     fatal error LNK1120: 1 unresolved externals    Release/main_curve_unita.exe
I hope you could help me to find a solution
best regardes.
KitturGanesh
Hi Debora,
I'll transfer to the Fortran forum for immediate support and resolution thereof. Appreciate your patience accordingly.
Kittur
TimP
As you don't say anything about how you got the .obj files nor which compilers you use, the error raises the suspicion that you may be mixing objects from different compilers or different settings of iface in ifort.
 I guess you refer to Windows which is the other Intel Fortran forum.
The procedure COMPR_PT is either missing or you're calling it from the main program with the wrong number of arguments. That the name ends with @172 tells me that you have the project set up to use the STDCALL calling convention, which was the default of Compaq Visual Fortran but not of Intel Fortran. As long as all of the program is compiled with the same setting, that works, but you do have to get the argument list right. @172 indicates that there are 43 actual arguments in the call (each CHARACTER argument counts as 2).
First, make sure that the procedure COMPR_PT exists and has the same number and data types of arguments as in the call. I suggest you set the project property Fortran > Diagnostics > Check Routine Interfaces to Yes - this will help diagnose mismatch errors. (You probably converted this from a CVF project which would not set that option.)
muzammil__muhammad
Good day sir here is my code in intel FORTRAN 77 for finding the roots
but after compiling it I got two errors
1)unresolved externals
2)unresolved external symbol _MAIN_references in function_main
how to resolve these two fatal errors?
here is my code
!calculating zeros for a function
double precision function zeroin(ax,bx,f,tol)
double precision ax,bx,f,tol
double precision a,b,c,d,e,eps,fa,fb,fc,tol1,xm,p,q,r,s
double precision dabs,dsign
c
c compute eps, the relative machine precision
c
eps = 1.0d0
10 eps = eps/2.0d0
tol1 = 1.0d0 + eps
if (tol1 .gt. 1.0d0) go to 10
c
c initialization
c
a = ax
b = bx
fa = f(a)
fb = f(b)
c
c begin step
c
20 c = a
fc = fa
d = b - a
e = d
30 if (dabs(fc) .ge. dabs(fb)) go to 40
a = b
b = c
c = a
fa = fb
fb = fc
fc = fa
c
c convergence test
c
40 tol1 = 2.0d0*eps*dabs(b) + 0.5d0*tol
xm = .5*(c - b)
if (dabs(xm) .le. tol1) go to 90
if (fb .eq. 0.0d0) go to 90
c
c is bisection necessary
c
if (dabs(e) .lt. tol1) go to 70
if (dabs(fa) .le. dabs(fb)) go to 70
c
c is quadratic interpolation possible
c
if (a .ne. c) go to 50
c
c linear interpolation
c
s = fb/fa
p = 2.0d0*xm*s
q = 1.0d0 - s
go to 60
c
c inverse quadratic interpolation
c
50 q = fa/fc
r = fb/fc
s = fb/fa
p = s*(2.0d0*xm*q*(q - r) - (b - a)*(r - 1.0d0))
q = (q - 1.0d0)*(r - 1.0d0)*(s - 1.0d0)
c
c adjust signs
c
60 if (p .gt. 0.0d0) q = -q
p = dabs(p)
c
c is interpolation acceptable
c
if ((2.0d0*p) .ge. (3.0d0*xm*q - dabs(tol1*q))) go to 70
if (p .ge. dabs(0.5d0*e*q)) go to 70
e = d
d = p/q
go to 80
c
c bisection
c
70 d = xm
e = d
c
c complete step
c
80 a = b
fa = fb
if (dabs(d) .gt. tol1) b = b + d
if (dabs(d) .le. tol1) b = b + dsign(tol1, xm)
fb = f(b)
if ((fb*(fc/dabs(fc))) .gt. 0.0d0) go to 20
go to 30
c
c done
c
90 zeroin = b
return
end
real function f(x)
f=x*x-4
return
end
jimdempseyatthecove
Muhammad,
Try adding the PROGRAM statement as the first line (following comment lines) of your source file.
Also, when posting code use the toolbar </> button.
Jim Dempsey
muzammil__muhammad
Thank you for your response Sir, I will do that and problem is solved
