- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Does the size of the hidden parameter (which is passed by value) containing the length of a string argument change with architecture? It appears to be 4 bytes on 32-bit, but I'm having a difficult time deciphering the generated assembler to determine if it is 4 or 8 bytes on an x86_64 compilation. The documentation that I've found is a little unclear on this. I'm having bizarre program behavior which leads me to believe I have stack corruption. The program is unfortunately crashing both valgrind and Intel Inspector.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
The string length is passed as what C would call size_t - that is indeed 8 bytes on x64.
I wouldn't expect a difference between the two calls in your example. Perhaps, rather than showing us snippets, you could provide a small but complete test case that shows the problem(s).
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Also, somewhat related question. If I have some declared structure STRUCT (which may or may not be multidimensional), what is the programmatic difference between:
CALL MYFUNC( STRUCT )
and
CALL MYFUNC( %REF(STRUCT) )
? The "MYFUNC" external is, in my practice, a C routine without a declared interface in the scope of the Fortran routine. The generated assembly is very different between the two lines in question, in that the former appears to be performing quite a bit more operations before pushing the address onto the base pointer register.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
If the number of arguments to the subroutine is small enough that the string length argument is passed in a register, it may be hard to determine whether 4 or 8 bytes are being used. If you add a few more arguments before producing the assembler code, you will see something such as
mov QWORD PTR [56+rsp], 5
Here, '5' is the length of the string that was passed as another argument. This should settle any doubt about the length of the length of the argument.
Unless you are interfacing Fortran and another language such as C, your program should not need to know how the string length is passed.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Actually, looking back I'm realizing I never mentioned that (in the OP). Yes, this is Fortran calling a C function.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I'd very strongly recommend using the C interoperability features in Fortran to declare the interface to the C routine. Note that this means no hidden arguments. You can now use CHARACTER(*) in a C interface and get the length from the C descriptor passed.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
That sounds like an option, however I hesitate a bit when I read notes about losing portability when using descriptors. Nonetheless, I'm looking through the include folder provided with the compiler (2015.2.164, in this case), and don't see any C header files with a typedef for a descriptor field. I realize the upper fields of the descriptors are variable based on the rank of the array, but if the lower 23 bits are fixed, and the upper bytes have structure (albeit repeating), it might be useful to include those templates in with the other definitions in this folder.
Also, I noticed while I was browsing this folder that, at least in my installed version, omp_lib.h appears to actually be a F90 file, rather than a C header (and oddly enough, different than omp_lib.f90).
As for the differences in passing implicitly via reference and using the %REF tag, I'll work on creating a reproducer and upload it as soon as I get a chance.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
C descriptors are a Fortran 2015 feature and were new in the Intel "2016" product. Yes, omp_lib.h is a Fortran file - there are a lot of Fortran include files with .h file types (not our choice - this comes from the MPI committee.) And yes,omp_lib.f90 is different (it's a module).
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
If I were to convert *all* of my C routine calls from Fortran to have interface definitions, I'd have to account for a couple (C-routines) which are actually variadic functions. This isn't an issue for us at the moment with implicit declarations of external subroutines, since Fortran just pushes the pointers to the arguments onto the stack, and then the C routine pulls the appropriate number of arguments back off based on the content. The documentation doesn't seem to suggest there's a way to properly prototype a C variadic function in Fortran. Should I just leave these functions as the old method (i.e. "pretending" we are Fortran on the other side by catching and pulling off hidden character size variables), or is there a smarter way to accomplish this?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
If by C you (could) mean C++ with variadic templates, then you could define a template that constructs a NULL terminated variable length struct containing values and/or references of your design. Then pass the reference to this struct for processing by your Fortran routine.
Jim Dempsey
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
See what you can do with !DEC$ ATTRIBUTES VARYING
