29279 Discussions
Horizontal and Vertical Scrollbar
timberwolf
I have created a dialog box with a list box in the resource.Under property style I have checked the vertical and horizontal scroll. When I execute the program andthe dialog box is displayed the list box shows the vertical scroll bar and it does work. Butit does not show thehorizontalscrollbar.
How would I make display both working vertical and horizontal scrollbar?
Any help is appriciated.
thanks
Jugoslav_Dujic
Valued Contributor II
This is (broken) by design. List boxes do not display horizontal scrollbar unless you tell them explicitly what's the length of the (longest) item, in pixels.
LB_SETHORIZONTALEXTENT message sets the length of scrollbar thumb and shows it if necessary. As any Windows message used with DFLOGM, it will work only when called from a dialog callback. In addition, you have to select the text into a DC and then measure it in pixels in order to obtain the length. Here you are (untested):
Code:
Subroutine SetHorzScrollbar(Dlg, idListBox)
use Dflogm
use Dfwin
implicit none
type(Dialog)::         Dlg
integer, intent(in)::  idListBox
integer::              hDC, b, hFont, nItems, i, hOldFont, maxLen
type(T_SIZE)::         SZ
character(200)::       sItem
hFont = DlgSendCtrlMessage(Dlg, idListBox, WM_GETFONT, 0, 0)
nItems = DlgSendCtrlMessage(Dlg, idListBox, LB_GETCOUNT, 0, 0)
hDC = GetDC(GetDlgItem(Dlg%hWnd, idListBox))
hOldFont = SelectObject(hDC, hFont)
maxLen = 0
do i = 0, nItems-1
  !Get the i-th item
  b = DlgSendCtrlMessage(Dlg, idListBox, LB_GETTEXT, i, LOC(sItem))
  !Measure the text length in pixels
  b = GetTextExtentPoint32(hDC, sItem, index(sItem,char(0)-1), SZ)
  maxLen = max(maxLen, SZ%cx)
end do
b = DlgSendCtrlMessage(Dlg, idListBox, LB_SETHORIZONTALEXTENT, maxLen+5, 0)
b = SelectObject(hDC, hOldFont)
b = ReleaseDC(GetDlgItem(Dlg%hWnd), idListBox)
end subroutine SetHorzScrollbar
If you fill in the list box on startup, you should define a startup (DLG_INIT callback) and call the subroutine above from there. If you change the list box' contents dynamically, you have to call the subroutine after every change (or optimize it a little so that you don't iterate through entire list every time).
Jugoslav
Message Edited by JugoslavDujic on 08-27-2004 09:44 AM
