29487 Discussions
How do I disable vectorisation for specific loops in ifort? (Mac OS 10.5)
jabakobob
When I try to run the following program:
PROGRAM TEST
implicit none
INTEGER, PARAMETER:: nx=100, ny=100
REAL, DIMENSION(:,:), ALLOCATABLE :: S
INTEGER:: i, j
ALLOCATE( S( -nx:nx, -ny:ny ) )
PRINT *,"Starting... "
do i=-nx,nx
do j=-ny,ny
S(i,j) = exp(-1.0 * ( i**2 + j**2 ) )
end do
end do
END PROGRAM
the following Error is thrown at runtime:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
(If I remove the print line, the error sudenly disappears)
If I compile with the -O1 option, everything works as expected.
I suspect that the problem might be related to vectorisation - how can I disable vectorisation for one loop in fortran with ifort?
I doubt it's vectorization. But there is a !DEC$ NOVECTOR directive you can put before the loop.
On which line does the segv occur?
jabakobob
I tried the !DEC$ NOVECTOR directive, and the code worked.
I can't say what line the segv occurs exactly, it only says unknown for line number.
If I add a PRINT statement in the outer loop, it prints the message once and then the segv occurs.
If I add a print statement in the inner loop, the code works as expected (and the loop isn't vectorized)
I also tried the !DEC$ NOVECTOR directive for vector operations, and it worked for simple ones (ie. a[:]=b[:]), but it doesn't seem to work for more complicated assignments like
a[1:n,1:n]=a[1:n,1:n]+a[0:n-1,0:n-1]
The compiler just spits out the following warning:
The statement following this DEC loop optimization directive must be an iterative do-stmt, a vector assignment, an OMP pdo-directive, or an OMP parallel-do-directive.
...and then vectorizes it anyways.
Please report the SEGV problem to Intel Premier Support.
jabakobob
Just reported the issue to Premier Support.... (Took me some time to sign up and answer all those security questions...) Thanks for your help!
