29343 Discussions
How do I download an older version of the Intel Fortran Compiler?
AndrewOng
Good day!
I am currently trying to compile and run simulation software that seems to require an older version of the Intel Fortran Compiler. I constantly see something along the lines of "PRJ0018 following environment variables not found IFORT17." I would like to ask where I could possibly download an older version of the compiler.
Thank you!
andrew_4619
there are so many old threads on the same topic such as https://community.intel.com/t5/Intel-Fortran-Compiler/Older-version-of-Intel-Fortran-Compiler/td-p/1179752  for example
Steve_Lionel
However... that particular error message doesn't mean you need an older version. Instead, it says that the project properties are referencing an IFORT17 environment variable, which is used to locate the compiler and libraries.  You'd need to find where this is being specified (as "$(IFORT17)") and change it to $(IFORT_COMPILER21) (assumes you have the latest version.
If you can attach a ZIP with the .vfproj file and the buildlog.htm from the Debug or Release folder, I can tell you where to look.
