29298 Discussions
How does one create a uniquely named Windows file via FORTRAN?
John6
Does anyone know a good way to create a new Windows file (via FORTRAN) which is uniquely named?
In C++ we can call GetTempFileNameW to get new uniquely named files. How can this be done via a FORTRAN call? What I would like is for a blank file to be created so that I can write to it, but it must be uniquely named. Seems like a call to a Windows-OS function should be doable. Is there a FORTRAN equivalent, so that an OS call is not needed?
Steven_L_Intel1
GetTempFileName is an Win32 API routine, not part of C++. You can call it in Fortran too. For example:
[fortran]use kernel32
integer(UINT) retval
character(MAX_PATH) filename
integer ipos
retval = GetTempFileName ('.'C,'XYZ'C,0,filename)
if (retval /= 0) then
  ipos = index(filename, CHAR(0))
  print *, "File name is ", filename(1:ipos-1)
else
  print *, "Call failed"
end if
end
[/fortran]
What GetTempFileName does is start out with a name based on the system time, and then it keeps incrementing the name until it finds one that is unused. You can write standard Fortran code to do this based on SYSTEM_CLOCK, an internal WRITE and an OPEN with STATUS='NEW'.
John6
Thanks, that is exactly what I was looking for (an example ofthe GetTempFileName Win32 API call from FORTRAN). Is there a Linux-OS equivalent? (The app I am working on is compiled on both Win32 and 64- bit OS) and Linux, using IVF).
Steven_L_Intel1
Not that I know of. Linux lacks a system library like Win32.
Try this.
[fortran]character(255) filename
call generate_temp_name('TMP', filename)
print *, trim(filename)
contains
subroutine generate_temp_name (prefix, outname)
implicit none
character(*), intent(in) :: prefix
character(*), intent(out) :: outname
real mrand
integer irand
logical ex
logical, save :: init = .false.
! Initialize random number generator
if (.not. init) then
  call random_seed
  init = .true.
  end if
do
! Get a random number
call random_number(mrand)
! Get the low 24 bits
irand = transfer(mrand, irand)
irand = iand(irand,Z'FFFFFF')
write (outname,101) trim(prefix),irand
101 format (A,Z6.6,'.tmp')
inquire (file=trim(outname),exist=ex)
if (.not.ex) exit
end do
! We have a name that does not exist (at least right now)
return
end subroutine generate_temp_name
end
[/fortran]
John6
Excellent. They both work great. I will use the latter because it is more portable. Interestingly enough, I had slightly modified the first example to not use a constant string for the prefix (I passed it in as a variable), and when (debug) stepping into the subroutine, the IDE crashed (VS 2005). The subroutine looked something like this:
Subroutine foooo (PrefixString, filename)
use kernel32
Implicit None
character(*) filename, PrefixString
!character(MAX_PATH) filename
integer ipos, LastNoNULL
retval = GetTempFileName ('.'C,PrefixString,0,filename)
End Subroutine foooo
called as: Call foooo ('text1_', tmp_file)
Steven_L_Intel1
The API routine wants a null-terminated string, but you left off the null.
John6
That is enough to cause the VS 2005 IDE to crash completely?
Steven_L_Intel1
Hard to say - depends on what the API code does with it. I'll try this later.
John6
Thanks, I appreciate the help. I did try with and without the trailing null, and the IDE crashed both times.
This occurred on the call into the subroutine, not when the IDE function was called, if that helps.
Steven_L_Intel1
I can't reproduce the crash.
John6
Huh... Well, not too surprising, these crashes are hard to reproduce... thanks for trying. I don't know whether it matters, but the caller was in one FORTRAN static library project and the callee was in a different static FORTRAN library. I thinkthe problem maylie somewhere in the passing of the string args, especially string constants. I wish I knew what I did that was so wrong, because I hate it when the IDE goes down.
jimdempseyatthecove
A minor variation in Steve's "try this" is to use his technique to create a new random named folder (directory) then within that directory, create sequentially numbered temp file names. In this manner you should never have a name conflict and as an additional benefit, should you decide to keep the temp files from a known good run, then latershould a production run ab-end (or during debugging), you now have a list of files that may be useful in running a post mortem of the ab-end.
Also, the temp files from program X are isolated from the temp files from program Y
Jim Dempsey
mecej4
Read the output of
man 3 mktemp
man 3 mkstemp
Steven_L_Intel1
That probably won't work well on Windows.
mecej4
True, but I was responding to #2, which was about Linux.
