I've been asked if we can 'modernise' the look of these display windows
Is it possible to set the font, the foregound and the background colours of a Console window?
Thankx and happy Friday to all...
Jimmy
You can customize many aspects. See Using Intel Visual Fortran to Create and Build Windows*-Based Applications for details. You'll be interested in SETFONT, SETTEXTCOLOR and more.
But the application crashes on the write when
SUBROUTINE MSGERR( ERRMSG )
IMPLICIT NONE
CHARACTER*(*) ERRMSG
write(*,*) errmsg
RETURN
END
Gets called :(
Any thoughts ?
when errmsg =
' *** This release of TRACKS expected a version V5.2 data file (found V7.0) '
but needed to use /iface:cvf to link in a couple of old external libraries we use.
Edit - later:
Interesting - been playing with QuickWin - can't get it to work with our old code - changing the interface settings on the program and libraries causes a number of link errors and/or some code to stop working. It looks like we would have to give our library calls a makeover to get it work.
Quickwin also appears to give us not quite what we want - a single simple output window. While I can maximise the child window and delete the menus 1 - 6, I can't get rid of the icon menu. And to make best use of the fonts I would need to make all the output routines use outgtext.
Is there really no way to set the text and background colors in a console window ? - thats all we actually need
Thankx again
Jim
C****************************************************************
PROGRAM MAIN
C
USE IFQWIN
WRITE(*,*)'Hello world'
pause
END PROGRAM MAIN
Built as a new console window in a new solution it works fine
Swap to using Quickwin libaries and you get Access Violations
If you create a new quickwin project it works fine.
There is a difference in the linker command line - one is /subsystem:windows the other is /subsystem:console - I think this may be where the problem lies...
I've just gone back to my original example - swapped both the runtime library and the subsystem settings and it works ....
Thanks for your support - I do hope your bosses realise how much we value it.
Cheers
Jim
There are third party screen drivers that support ANSI escape sequences, too.
And ansi escapes only work if you have the ansi driver installed - and are obnoxious if you dont...
There are two ways to make them stick. I usually have to set these options only after a fresh install of Windows.
(i) If you change them through Properties, when you click OK after changing, you will be offered a choice to apply the changes to the shortcut (sticky) or just for the current session.
(ii) If you change them through Defaults, the changes will be in effect the next time that you run the shortcut.
In Windows-7, you may have to open a CMD window with Administrator privileges before changing the settings in order to make the changes stick.
Glad to hear you have it working.
There is a set of Win32 API functions to do most of the tasks you want. Please take a look attopics 'Console Functions' and
'Console Screen Buffers' on MSDN.
Sergey
Or, if you feel adventurous, you can try the undocumented, but extant API functions described here:
http://blogs.microsoft.co.il/blogs/pavely/archive/2009/07/23/changing-console-fonts.aspx
I believeyou sent mescreenio.lib and oldnames.lib many years ago. If they work with Intel Fortran and Windows 7, they may be useful in this case.
Gabriel
Steve,
We are also considering porting our programs to QuickWin. The kids these days seem lost when it comes to the console. We also need to be compatible with gfortran on Windows and Linux because some people just like to cause me grief. ;-) I was hoping we could fairly easily wrap QuickWin around our console apps. We already segregate all system-specific code in files for each system/compiler. No system-specific code goes in the main files. We don't even write to the screen except in the system files. We use the same system files for all our programs.
One reason for going to QuickWin is that we would like to know the size of the console so we know where to wrap messages. Apparently, it is not possible to find the width of a cmd.exe console from within a program, but it is with QuickWin windows. Colors would be nice too.
One concern I have is performance, which is of paramount importance. We can afford to lose 10% or so and hope for faster computers next year, but a factor of two or more would be problematic for our simulations.
Any advice would be greatly appreciated.
Marshall
I am not aware that using QuickWin impacts performance. The only possible issue there is if your program outputs LOTS of text - rendering the text to the window is more compute-intensive than in a console window.
If you want this to work in gfortran, avoid quickwin.
I tested this in gfortran:
[fortran]module console_stuff
use ISO_C_BINDING
implicit none
private
integer, parameter, public :: BOOL = C_INT
integer, parameter, public :: HANDLE = C_INTPTR_T
integer, parameter, public :: ULONG = C_LONG
integer, parameter, public :: SHORT = C_SHORT
integer, parameter, public :: WORD = C_SHORT
integer, parameter, public :: DWORD = C_LONG
integer, parameter, public :: COLORREF = DWORD
integer(DWORD), parameter, public :: STD_OUTPUT_HANDLE = -11
integer(WORD), parameter, public :: FOREGROUND_BLUE = int(Z"1",WORD)
integer(WORD), parameter, public :: FOREGROUND_GREEN = int(Z"2",WORD)
integer(WORD), parameter, public :: FOREGROUND_RED = int(Z"4",WORD)
integer(WORD), parameter, public :: FOREGROUND_INTENSITY = int(Z"8",WORD)
integer(WORD), parameter, public :: BACKGROUND_BLUE = int(Z"10",WORD)
integer(WORD), parameter, public :: BACKGROUND_GREEN = int(Z"20",WORD)
integer(WORD), parameter, public :: BACKGROUND_RED = int(Z"40",WORD)
integer(WORD), parameter, public :: BACKGROUND_INTENSITY = int(Z"80",WORD)
integer(WORD), parameter, public :: COMMON_LVB_LEADING_BYTE = int(Z"100",WORD)
integer(WORD), parameter, public :: COMMON_LVB_TRAILING_BYTE = int(Z"200",WORD)
integer(WORD), parameter, public :: COMMON_LVB_GRID_HORIZONTAL = int(Z"400",WORD)
integer(WORD), parameter, public :: COMMON_LVB_GRID_LVERTICAL = int(Z"800",WORD)
integer(WORD), parameter, public :: COMMON_LVB_GRID_RVERTICAL = int(Z"1000",WORD)
integer(WORD), parameter, public :: COMMON_LVB_REVERSE_VIDEO = int(Z"4000",WORD)
integer(WORD), parameter, public :: COMMON_LVB_UNDERSCORE = int(Z"8000",WORD)
type, bind(C), public :: T_COORD
integer(SHORT) x
integer(SHORT) y
end type T_COORD
type, bind(C), public :: T_SMALL_RECT
integer(SHORT) Left
integer(SHORT) Top
integer(SHORT) Right
integer(SHORT) Bottom
end type T_SMALL_RECT
type, bind(C), public :: T_CONSOLE_SCREEN_BUFFER_INFO
type(T_COORD) dwSize
type(T_COORD) dwCursorPosition
integer(WORD) wAttributes
type(T_SMALL_RECT) srWindow
type(T_COORD) dwMaximumWindowSize
end type T_CONSOLE_SCREEN_BUFFER_INFO
public GetConsoleScreenBufferInfo
interface
function GetConsoleScreenBufferInfo(hConsoleOutput, &
lpConsoleScreenBufferInfo) bind(C,name='GetConsoleScreenBufferInfo')
import
implicit none
!gcc$ attributes stdcall :: GetConsoleScreenBufferInfo
integer(BOOL) GetConsoleScreenBufferInfo
integer(HANDLE), value :: hConsoleOutput
type(T_CONSOLE_SCREEN_BUFFER_INFO) lpConsoleScreenBufferInfo
end function GetConsoleScreenBufferInfo
end interface
public GetLastError
interface
function GetLastError() bind(C,name='GetLastError')
import
implicit none
!gcc$ attributes stdcall :: GetLastError
integer(HANDLE) GetLastError
end function GetLastError
end interface
public SetConsoleTextAttribute
interface
function SetConsoleTextAttribute(hConsoleOutput, wAttributes) &
bind(C,name='SetConsoleTextAttribute')
import
implicit none
!gcc$ attributes stdcall :: SetConsoleTextAttribute
integer(BOOL) SetConsoleTextAttribute
integer(WORD), value :: wAttributes
end function SetConsoleTextAttribute
end interface
public GetStdHandle
interface
function GetStdHandle(nStdHandle) bind(C,name='GetStdHandle')
import
implicit none
!gcc$ attributes stdcall :: GetStdHandle
integer(HANDLE) GetStdHandle
integer(DWORD), value :: nStdHandle
end function GetStdHandle
end interface
end module console_stuff
program main
use console_stuff
implicit none
integer(BOOL) result4
integer(HANDLE) hConsoleOutput
hConsoleOutput = GetSTdHandle(STD_OUTPUT_HANDLE)
result4 = GetConsoleScreenBufferInfo(hConsoleOutput,lpConsoleScreenBufferInfo)
write(*,'("Buffer width = ",i0,", Buffer Height = ",i0)') &
lpConsoleScreenBufferInfo%dwSize
wAttributes = iany([FOREGROUND_RED,FOREGROUND_INTENSITY,BACKGROUND_BLUE])
result4 = SetConsoleTextAttribute(hConsoleOutput,wAttributes)
write(*,'(a)') 'Hello, world'
result4 = SetConsoleTextAttribute(hConsoleOutput,lpConsoleScreenBufferInfo%wAttributes)
end program main[/fortran]
