29278 Discussions
How to download older version of Intel oneAPI HPC Toolkit for Centos 7?ins
tanglaoya
Dear administrator,
I need to install Intel oneAPI HPC Toolkit on Centos 7 (I can't change the OS), I tried the latest version and build my program with -mkl, the following errors displayed:
/opt/intel/oneapi/compiler/2025.2/bin/compiler/xfortcom: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /opt/intel/oneapi/compiler/2025.2/bin/compiler/xfortcom)
/opt/intel/oneapi/compiler/2025.2/bin/compiler/xfortcom: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /opt/intel/oneapi/compiler/2025.2/bin/compiler/xfortcom)
therefore, I need to install an older version, could you please give me the best version and download link to get this package?
Tang Laoya
andrew_4619
At the top of the forum there is a sticky topic on "
tanglaoya
Thank you very much for your kindly reply.
However, when logged into the download center, the following error message displayed:
An unexpected error occurred. Please refresh and try again or contact Intel support.
Tang Laoya
andrew_4619
Well if that persists raise a ticket if you have support, otherwise and Intel person might pick that up for here in due course.
JohnNichols
Valued Contributor III
I think you are going to have to be creative and go looking for the files, if not on your computer then try another installation.
I found this https://stackoverflow.com/questions/55363823/redhat-centos-glibc-2-18-not-found
You might be out of luck.
tanglaoya
However, after installed Redis 3.2 and launched the service, the same build errors still displayed.
Which steps did I miss?
Tang Laoya
Ron_Green
Centos and Redhat 7 support was dropped with the 2023 versions.  You'd need a 2022 version and that is no longer available for download.
Ron_Green
CHeck to see where ifx is finding libc.so.  use the commands
which ifx
ldd <path>/ifx
Below is an example.  'ldd' will show you where the compiler is finding libc.so
$ which ifx
/nfs/pdx/disks/cts2/tools/oneapi/2025.2.0/compiler/2025.2/bin/ifx
$ ldd /nfs/pdx/disks/cts2/tools/oneapi/2025.2.0/compiler/2025.2/bin/ifx
	linux-vdso.so.1 (0x000076242d7e6000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x000076242d6eb000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x000076242d6bd000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x000076242d6b8000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x000076242d6b1000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x000076242d400000)
	/lib64/ld-linux-x86-64.so.2 (0x000076242d7e8000)
tanglaoya
Thank you very much for your kindly reply. The 'ldd' shows the following information:
$ldd /opt/intel/oneapi/compiler/2025.2/bin/ifx
	linux-vdso.so.1 =>  (0x00007ffd1d1f4000)
	libm.so.6 => /lib64/libm.so.6 (0x00007efce37c4000)
	libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007efce35ae000)
	libdl.so.2 => /lib64/libdl.so.2 (0x00007efce33aa000)
	libpthread.so.0 => /lib64/libpthread.so.0 (0x00007efce318e000)
	libc.so.6 => /lib64/libc.so.6 (0x00007efce2dc0000)
	/lib64/ld-linux-x86-64.so.2 (0x00007efce3ac6000)
what is next step?
Tang Laoya
