How to get the address of an array pointer?
Li_Dong
Dear all,
I would like to get the address of an array pointer. The prototype codes are as following:
program main
    implicit none
    type foo
        integer, allocatable :: i(:)
        integer j
    end type
    type(foo) a
    print *, "The address of a is ", loc(a)
    print *, "The address of a%i is", loc(a%i) ! I expect the same address as a.
end program main
My final target is to get the address of "a" with type(foo) through the address of "a%i", since "i" is the first part of type(foo).
Thanks in advance!
Li
IanH
As explained elsewhere, the descriptor for the allocatable component a%i might (there is no guarantee) be the first thing in the storage for foo, but the actual data for a%i will be somewhere completely different. loc(a%i) and loc(a) will be unrelated.
Li_Dong
So if I want to associate the address of "loc(a%i)" with "a", I can only use hash table?
IanH
(Fascinating - quoting in a response reveals the quotee's email address. Well, at least I won't have to struggle to remember my login id from now on.) Noting that I'm not even vaguely familiar with your requirements - doing a reverse lookup on the pointer is one possibility, but before doing that I'd have a good think about what you are trying to do.
jimdempseyatthecove
Li Dong wrote:
Dear all,
program main
    implicit none
    type foo
        integer j
    end type
    type(foo) a
end program main
Thanks in advance!
Li
loc(a) is the address of type foo variable a (think of C++ struct or class). Within variable a (struct foo a) is an array descriptor named "i" (think of this as C++ vector < int > i) where: loc(a%i) is same/equivilent to loc(a%i(1)), meaning the loc of an array is the location of the first element of the array and not the address of the array descriptor. This is unlike C++ where address of i is the address of the vector and not the address of i[0]. i being allocatable, places the (assumed) allocated array data outside the bounds of the type foo object. It would be easier to associate loc(j) with the array i. Jim Dempsey
