How can I use a static library in a Intel Fortran Project and at the same time, include some of the library subroutines in other parts of the project with some changes? In other words, in the case that I have two definitions of the same subroutine, How can I ask the program to use the subroutine that is included in the project rather than the same subroutine in the library?
- « Previous
- 1
- 2
- Next »
Why won't this work?
1) Put the subroutine ADD that you really want to invoke in a module.
2) USE the module in the program unit where you really want to invoke it.
3) Give the subroutine a different linker name with !DEC$ ATTRIBUTES ALIAS
Even step 3 above seems unnecessary because a module procedure already has a different linker name.
If the module won't be available at the time the prospective caller is compiled, you could still write out an interface block with a different linker name as specified in 3 above. I don't think you are reduced to LoadLibrary/GetProcAddress/C_F_PROCPOINTER to get this to work.
Ahmed A. wrote:What is the error message? Is it compiler or linker error message? You have a working simple example, what design changes exist between the simple example and the full library? Jim Dempsey
Hi Mr. Dempsey
I have tired your method with the simple project we have here and it works fine but with our project that has very big library it does not work it gives me some error, are there any conditions this way will work only or it can work with any project.
Many Thanks
Ahmed
I compiled the 3 included files as:
ifort add.for source1.for sub.for
Output was:
CALLED HERE ADD NEW 50.0000000000000
2 5 50.0000000000000
THIS IS THE MAIN
- « Previous
- 1
- 2
- Next »
