How to link a dll type file ?
lyfhq
If compile the codes mylib.f to dll type with the following command:
ifort /dll /exe:mylib.dll mylib.f
how to link the program that need the mylib.dll with ifort
command?
anthonyrichards
New Contributor III
I think you just add the'mylib.lib' file, generated when youcreate the DLL,toyour FORTRANproject and ensure all the routines that you need to access fromthe DLLare named as DLLIMPORT 'ed names in your fortran code using compiler directives inside INTERFACE blocks for the routines.
lyfhq
Thank you ,anthonyrichards. Your advice works !
