Hi guys,
I've exported a table from Matlab in a .csv file (attached to this post: "NEOs_asteroids_filtered.csv" ).
I read the file in order to create a vector of six element (6 orbital parameter) for each asteroid (whose data are stored in the rows of my .csv file).
I created a derived data type
named NEO
and then I read all data in a variable named asteroids
Now I would want to perform something like this:
matrix = (asteroids%a, asteroids%e, asteroids%i, asteroids%om, asteroids%w, asteroids%ma)
matrix of dimension: num_row = number of asteroids and num_columns = number of orbital elements (i.e. only 6 columns instead of 11). How can I perform this task?
Can you help me in the coding?
Here my attempt code for data reading (main):
program LagrangePoints_Main
use DataType
use Constants
implicit none
! NEOs data :
! pdes Object primary designation
! IAU name Object IAU name
! Epoch Epoch Julian Date (TDB: Barycentric Dynamical Time): Julian Date of osculating elements
! a Semi-major axis (AU)
! e Eccentricity
! i Inclination w.r.t. xy-plane (deg)
! om Longitude of Ascending Node w.r.t. to ecliptic/equinox (deg)
! w Argument of Perihelion wrt to ecliptic/equinox (deg)
! ma Mean anomaly (deg)
! q Perihelion distance (AU)
! ad Aphelion distance (AU)
! Declarations
character*100 :: input_path,input_filename_ast, output_path, output_filename_ast
character*118 :: str_line
character*30, dimension (4) :: str_output !for header of output file for Matlab
integer :: i,iflag, n_lines
type(NEO), dimension (:), allocatable :: asteroids
real(pr), dimension (:,:), allocatable :: elem_matrix
! Definition of constants, paths names and file names
input_path = 'D:\OneDrive\MSc_Thesis\Projects\NEOs_orbits\InputFiles\'
input_filename_ast = 'NEOs_asteroids_filtered.csv'
!output_path = 'D:\OneDrive\MSc_Thesis\Projects\NEOs_orbits\OutputFiles\'
!output_filename_ast = 'Asteroids_state_vec.txt'
! Reading of asteroids data
open(unit = iu_in, file = trim(input_path) // trim(input_filename_ast), status='old', &
access = 'sequential',form = 'formatted', action='read')
! Count lines
n_lines = 0
do
read(iu_in,*,iostat = iflag)
if (iflag/=0) exit
n_lines = n_lines + 1
enddo
rewind(iu_in)
! Variables allocation
allocate(asteroids(n_lines))
read (iu_in,'(a35)') str_line
do i = 1,55
read(iu_in,*) asteroids(i)
enddo
close(unit = iu_in, status='keep')
!allocate(elem_matrix(55,3))
!do i =1,55
! elem_matrix = (asteroids%a(i), asteroids%e(i), asteroids%i(i))
!enddo
print *, asteroids
! Convert Mean anomaly to true anomaly
stop
end program LagrangePoints_Main
I had a look at the file: the fields appear to be separated by commas, which is nice because that can be handled automatically by list-directed input (read( line, *) ...), but the first field may contain a space, which serves as a field separator for list-directed input as well. So the strategy I would use is:
- Read in the complete line (easiest if there is a reasonable maximum, otherwise there are routines around to read a complete line of arbitrary length )
- Find the first comma via the index intrinsic function and split off the first field. Store the rest of the line in, say, a variable rest
- You can even remove the next comma as there is nothing in between
- Then use "read( rest, * ) x1, x2, x3, ..." to read the remaining data
Nothing wildly complicated.
Wrt your question about the empty field: list-directed input will skip that, not touching the corresponding variable. Try it with a few simple examples in a test program.
Solution 1 - try it and report the errors
Solution 2 - use Notepad and change the , , to something like , dummy,
Solution 3 there are several read subroutines on this forum, you will need to search that show you how to solve this problem is read the line and look for the commas.
Thanks @JohnNichols , can you write the link where I can find the read subroutines on this forum?
P.S. Sorry, I answered in wrong way here.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
