29274 Discussions
How to set FTZ and DAZ flag for ifc 7.1 ?
dfumento5
The ifc 7.1 manuals are no longer available. I can see how in ifort
version 8 how to set FTZ (-ftz) and the DAZ flag is set automatically for P3 and above.
There is no -ftz flag for ifc 7.1. Also how do you set the DAZ flag in ifc 7.1?
David
TimP
The primary alternative to the command line option, which would set mxcsr in main(), is to use the setcsr() intrinsics from . A call to a simple gcc function would do. IIRC, there was no change in the way DAZ was handled between 7.1 and 8.0.
dfumento5
Could you tell me the exact 'C' subroutine for setting the FTZ bit?
David
TimP
e.g. Fortran code:
call setftz
C code:
#include
void setftz_(){
_MM_SET_FLUSH_ZERO_MODE (_MM_FLUSH_ZERO_ON);
While not standard C syntax, it is supported by current gcc, icc, and MSVC compilers, as well as (supposedly), by PGI C and Fortran compilers.
dfumento
Thanks!
