Hyperbolic perplexity
mecej4
The intrinsic function ACOSH with complex argument was added to Fortran in Fortran 2008. Since this function is multi-valued for complex arguments, a convention is needed for what the return value should be. The F2008 (13.7.5) and F2018 (16.9.5) standards state:
5 Result Value. The result has a value equal to a processor-dependent approximation to the inverse hyperbolic cosine function of X. If the result is complex the imaginary part is expressed in radians and lies in the range 0 ≤ AIMAG (ACOSH (X)) ≤ π
In contrast, the Intel Fortran Development Reference Guide says:
If the result is complex, the real part is non-negative, and the imaginary part is expressed in radians and lies in the range -pi <= AIMAG (ACOSH (x)) <= pi.
The following program outputs a result with the imaginary part negative:
program xacosh
   implicit none
   complex :: z = (-0.01, -0.01)
   print 10, 'z', z, 'acosh(z)', acosh(z)
10 format(1x,A,T10,'( ',ES11.3,' , ',ES11.3,' )')
end
The result:
S:\LANG\ftn95>acosh
 z       (  -1.000E-02 ,  -1.000E-02 )
 acosh(z)(   1.000E-02 ,  -1.581E+00 )
Please clarify if the deviations ( w.r.t. (a) sign of the real part and (b) range of the imaginary part) from the standard are deliberately intended, and any reasons for the choices, if available. Thank you in advance.
Steve_Lionel
D:\Projects>nagfor -o t.exe t.f90
NAG Fortran Compiler Release 7.1(Hanzomon) Build 7114
[NAG Fortran Compiler normal termination]
D:\Projects>t.exe
It's an error in the F2018 standard, corrected by interpretation request F18/0001. The corrected text says, "If the result is complex the real part is nonnegative, and the imaginary part is expressed in radians and lies in the range −π ≤ AIMAG (ACOSH (X)) ≤ π"
JohnNichols
Honored Contributor I
This is really fascinating,  the https://www.geeksforgeeks.org/acosh-function-for-complex-number-in-c/  site seems to agree with your Intel observations.  They provide a couple of quick samples.
Running their sample but with the -0.000 I get -pi.
-1.58 is just 335 degrees in the -PI to PI system.
Ron_Green
This is an interesting one.  gfortran 12.0.1 is in agreement in values with ifort/ifx.   I will ask advice from someone more familiar with this function, and the F08 Standard.  I don't have the NAG compiler myself but I'll ask someone to try it with NAG.
Steve_Lionel
D:\Projects>t.exe
mecej4
The portion "the imaginary part is expressed in radians" strikes me as odd, since the imaginary part (with the i removed) does not represent an angle -- it is just a real number.
If one wishes to think about the Argand Diagram, the real part is the x-coordinate and the imaginary part is the y-coordinate.  It is only after the point (x, y), where z = x + i y, is plotted and a line drawn to it from the origin that we may speak of angles.
