29487 Discussions
I/O formatting read data from a previous record
h_amini
Hi there
Is it possible to read data from a previous line?
For example my program needs to read the third line (30000) first, then the first line (10000) of the following data file:
01.txt:
10000
20000
30000
I can do it by closing and reopening the data file, but there may be a faster solution, e.g. a command for reading data from a specific line number.
INTEGER A,N
OPEN(unit = 1, file = '01.txt')
n = 2
READ (1,11)A
PRINT*, A
CLOSE(unit = 1)
n = 1
READ (1,11)A
PRINT*, A
CLOSE(unit = 1)
11 FORMAT(/,I<5>)
end
Any comment would be very much appreciated.
Hamid
Les_Neilson
Valued Contributor II
Look at BACKSPACE for getting the previous record,
and REWIND to go back to the begining of the file without needing to close and re-open it.
Les
h_amini
Quoting - Les Neilson
Les
Many thanks.
jimdempseyatthecove
Also consider
A2 = A1
A1 = A
READ(fmt) A
Then when A is your trigger (30000 in example) use A2
Use an array of prior results when the go-back is larger than a few.
Jim
bmchenry
New Contributor II
i would suggest tryinginternal reads into a character array and then simply setting the counter back 2 when special situations are encounteredto read prior records.
depending on how large your input dataset is, and how many times you need to check a prior value, you can save valuable time by simply inputting input in arrays (groups of 3) or more?
whenever you doing multiple open/close/rewind you are slowing things down.
memory is cheap and fast there's lots of it out there.
brian
