running in batch mode
Deleted_U_Intel
Why do I sometimes (up to 33%) get the following message when running my *.exe file in batch mode: "The system can not find the file specified". The output from my exe file is o.dat. I am running this batch file in the dos window on my system for which the operating system is VISTA. A segment of the batch file is below:
@echo off
rem ***********************************
rem this batch file is for running multiples
rem of penetration curves
del o*.dat
rem ************STARTING CYCLE 1*******
time/t
start /wait PHEV_BATCH
ren o.dat o1.dat
echo done with cycle 1
rem goto end
It seems that sometimes the system, despite the /wait switch, is getting out ahead of the application before it has completed writing out the o.dat file.
Your suggestions would be appreciated.
thank you!
John
jimdempseyatthecove
John,
When you receive the error message does o.dat exist?
If it does not exist then PHEV_BATCH did not create the file (or created it in a different directory than which you expected).
If it does exist (where it is expected) then this may be a lazy close issue. Try
:wait
if not exist o.dat goto wait
ren o.dat o1.dat
The above will hang if o.dat is not created. Consider the following
if not exist o.dat DIR >NULL
if not exist o.dat echo o.dat not found
if not exist o.dat ren o.dat o1.dat
Jim Dempsey
jimdempseyatthecove
I hope you caught the error in the last statement (remove the "not")
Jim
