29386 Discussions
I can not create rebar with CreateWindowEx()
lm_lxt
Hi All,
The code is following:
hRebar=CreateWindowEx (WS_EX_TOOLWINDOW, &
"ReBarWindow32"C, &
"jhlj", &
ior(WS_VISIBLE,,WS_CHILD),&
0,&
0,&
0,&
0,&
hWnd, &
null,&
HInst, &
NULL)
BUT it can not show the rebar window.I don't kown why.
Many thanks for any help!!
Jugoslav_Dujic
Valued Contributor II
Well, for the start, it has zero dimensions so it can hardly be visible. Besides, the rebar's behavior is fairly peculiar, as it automatically accomodates its dimensions to the parent window client area and included toolbars; it might be easily the case that you won't see anything until you add a child (toolbar) into it.
In any case, Spy++ is your friend.
lm_lxt
Many Thanks!But I have another problem that the width of verticalrebar have the same value in any case! The following is my resource:
module Constant
use IFwin
use COMCTL32
integer*4 hInst ,hh
character*200 string
logical*4 results
integer*4,parameter:: NumButton = 4
type( T_TBBUTTON ), DIMENSION(*) :: tbrButtons( NumButton )
end module Constant
module Toolbar
integer*4,parameter:: IDC_CURSOR1 =101
integer*4,parameter:: IDI_ICON1 =102
integer*4,parameter:: IDR_MENU1 =103
integer*4,parameter:: ID_40001 =40001
integer*4,parameter:: ID_40002 =40002
integer*4,parameter:: ID_40003 =40003
integer*4,parameter:: ID_40004 =40004
end module Toolbar
integer function WinMain( hInstance, hPrevInstance, lpszCmdLine, nCmdShow )
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_WinMain@16' :: WinMain
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'WinMain' :: WinMain
!DEC$ ENDIF
use Constant
use Toolbar
integer*4 hInstance
integer*4 hPrevInstance
integer*4 nCmdShow
integer*4 lpszCmdLine
integer*4 i,istyle
interface
integer*4 function MainWndProc ( hwnd, mesg, wParam, lParam )
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_MainWndProc@16' :: MainWndProc
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'MainWndProc' :: MainWndProc
!DEC$ ENDIF
integer*4 hwnd
integer*4 mesg
integer*4 wParam
integer*4 lParam
end function
end interface
type ( T_WNDCLASS ) wc
type ( T_MSG ) mesg& nbsp;
integer*4 hWnd,Hbitmap1
integer*4 COLOR
character*100 lpszClassName
character*100 lpszAppName
COLOR=9
lpszClassName ="GenericClass"C
lpszAppName ="hhh"C
if(hPrevInstance .eq. 0) then
wc%lpszClassName = LOC( lpszClassName )
wc%lpfnWndProc = LOC( MainWndProc )
wc%style = 0
wc%hInstance = hInstance
wc%hIcon = LoadIcon( hInstance, IDI_ICON1)
wc%hCursor = LoadCursor( hInstance, IDC_CURSOR1 )
wc%hbrBackground = ( COLOR_WINDOW+COLOR )
wc%lpszMenuName = IDR_MENU1
wc%cbClsExtra = 0
wc%cbWndExtra = 0
i = RegisterClass( wc )
end if
hh=hInstance
hWnd = CreateWindowEx( 0,
& nbsp; lpszClassName, lpszAppName,
INT( WS_OVERLAPPEDWINDOW ),
CW_USEDEFAULT,
0,
CW_USEDEFAULT,
0,
NULL,
NULL,
hInstance,
NULL
i = ShowWindow( hWnd, SW_MAXIMIZE )
i = UpdateWindow( hWnd )
do while( GetMessage (mesg, NULL, 0, 0) .NEQV. .FALSE.)
i = TranslateMessage( mesg )
i = DispatchMessage( mesg )
end do
WinMain = mesg%wParam
return
end function WinMain
integer*4 function MainWndProc ( hWnd, mesg, wParam, lParam )
!DEC$ ELSE
!DEC$ ENDIF
use Constant
use Toolbar
integer*4 hWnd
integer*4 mesg
integer*4 wParam
integer*4 lParam
interface
logical function DialogFunc ( hdWnd, mesg, wParam, lParam )
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_DialogFunc@16' :: DialogFunc
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'DialogFunc' :: DialogFunc
!DEC$ ENDIF
integer*4 hdWnd
integer*4 mesg
integer*4 wParam
integer*4 lParam
end function
end interface
integer*4 hdc, hRebar,Hbitmap1,dwBtnSize
type(t_REBARINFO) rbi
type(t_REBARBANDINFO) rbBand
select case ( mesg )
case(WM_CREATE)
call INITCOMMONCONTROLS()
hRebar=CreateWindowEx (0, &
"ReBarWindow32"C, &
"dsh", &
ior(ior(ior(ior(ws_visible,WS_child),WS_THICKFRAME),ior(WS_caption,ws_sysmenu)),ior(CCS_left,CCS_NOPARENTALIGN )),&
CW_USEDEFAULT,&
CW_USEDEFAULT,&
0,&
300,&
hWnd, &
ID_40001,&
hh, &
NULL)
call InitToolBar( )
Hbitmap1=LoadImage(hRebar,"toolbar1.bmp",IMAGE_BITMAP, 0, 0, LR_LOADFROMFILE)
hInst = CreateToolbarEx( hRebar, &
ior( ior(WS_VISIBLE ,WS_CHILD),tbstyle_wrapable),&
null, &
NumButton, &
null, &
Hbitmap1, &
tbrButtons, &
NumButton, &
35,35,0,0, &
sizeof(tbrButtons(1)))
results= MoveWindow(hRebar,50,50,100,100,TRUE)
case (WM_SIZE)
! hdc=SendMessage(hRebar, WM_SIZE, wParam, lParam)
! hdc=SendMessage(hInst, WM_SIZE, SIZE_RESTORED, lParam)
case( WM_COMMAND )
select case( wParam )
c ase( ID_40001 )
case( ID_40002 )
hdc=MessageBox(hWnd,"open","open",MB_OK)
case( ID_40003 )
hdc=MessageBox(hWnd,"save","save",MB_OK)
case( ID_40004 )
call PostQuitMessage( 0 )
end select
!case ( WM_SIZE )
! hdc=SendMessage(hInst,WM_SIZE,SIZE_RESTORED,iParam)
case ( WM_DESTROY )
case default
MainWndProc = DefWindowProc( hWnd, mesg, wParam, lParam )
end select
return
end function MainWndProc
subroutine InitToolBar( )
use Constant
use Toolbar
integer j
j = ID_40001
do i = 1 ,NumButton
tbrButtons(i)%iBitmap = i-1
tbrButtons(i)%idCommand = j
tbrButtons(i)%fsState = TBSTATE_ENABLED
tbrButtons(i)%fsStyle = TBSTYLE_BUTTON
tbrButtons(i)%dwData = 0
tbrButtons(i)%iString = 0
j =j+1
enddo
return
end subroutine InitToolBar
Jugoslav_Dujic
The same value of width as... ?
I'm not too familiar with rebars (I made a working one long time ago). Take a look on "common control styles" and "Rebar control styles" pages. I think you need one or more of CCS_VERT, RBS_VARHEIGHT and CCS_LEFT/CCS_RIGHT. CCS_NOPARENTALIGN should prevent it from auto-alignment.
lm_lxt
Many thanks! I got the answers.
