- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi all,
I try run this Parallel Programming in Fortran 90 using OpenMP
! ifort -openmp -parallel -fpp Hello.f90
PROGRAM HOLA
IMPLICIT NONE
REAL, SAVE :: A
REAL, DIMENSION (5), SAVE :: B
REAL, ALLOCATABLE, DIMENSION(:,:), SAVE :: C
!$OMP THREADPRIVATE(A,B,C)
A=5.0
B = 10.0
ALLOCATE(C(2,2))
C = 666.0
!$OMP PARALLEL DEFAULT(NONE) COPYIN(A,B,C)
!$OMP SECTIONS
!$OMP SECTION
WRITE(*,*)"HELLO",A,B
WRITE(*,*)"%%%%%%%%%%%%%%%%%%%%"
WRITE(*,*)C
!$OMP SECTION
WRITE(*,*)"HI",A,B
WRITE(*,*)"@@@@@@@@@@@@@@@@@@@@@@"
WRITE(*,*)C
!$OMP END SECTIONS
!$OMP END PARALLEL
STOP
END PROGRAM HOLA
I get this message
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
a.out 00000000004118B6 Unknown Unknown Unknown
a.out 00000000004036B5 Unknown Unknown Unknown
libiomp5.so 00007F7454EB60D3 Unknown Unknown Unknown
I use this command
ifort -openmp Hello.f90
I am also running the ldd command
linux-vdso.so.1 => (0x00007fff253ff000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f2aaa8e2000)
libiomp5.so => /opt/intel/composer_xe_2011_sp1.11.339/compiler/lib/intel64/libiomp5.so (0x00007f2aaa5f3000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f2aaa3d5000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f2aaa040000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f2aa9e29000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f2aa9c25000)
/lib64/ld-linux-x86-64.so.2 (0x00007f2aaab7c000)
and i read and work with the information in this page
http://software.intel.com/en-us/articles/determining-root-cause-of-sigsegv-or-sigbus-errors/
Could someone help me to solve this problem ?
Thanks very much
Victor
PROGRAM HOLA
IMPLICIT NONE
REAL, SAVE :: A
A=5.0
B = 10.0
ALLOCATE(C(2,2))
C = 666.0
!$OMP SECTIONS
!$OMP SECTION
WRITE(*,*)C
!$OMP SECTION
WRITE(*,*)"HI",A,B
WRITE(*,*)C
!$OMP END SECTIONS
!$OMP END PARALLEL
STOP
END PROGRAM HOLA
I get this message
I use this command
Thanks very much
Victor
- Balises:
- Intel® Fortran Compiler
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The !$OMP COPYIN clause copies from the outside parallel region name space to the PRIVATE copies of those named entities. This does not copy to THREADPRIVATE variables.
Either
a) Remove THREADPRIVATE(A,B,C) and add the OpenMP clause PRIVATE(A,B,C) with COPYIN
b)[fortran]PROGRAM HOLA IMPLICIT NONE REAL, SAVE :: A REAL, DIMENSION (5), SAVE :: B REAL, ALLOCATABLE, DIMENSION(:,:), SAVE :: C !$OMP THREADPRIVATE(A,B,C) !$OMP PARALLEL A=5.0 B = 10.0 ALLOCATE(C(2,2)) C = 666.0 !$OMP END PARALLEL ! (other code here if you wish) !$OMP PARALLEL DEFAULT(NONE) ... [/fortran]Jim Dempsey
Either
Lien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Either
Either
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Jim,
Victor
Victor
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
also http://software.intel.com/en-us/articles/determining-root-cause-of-sigsegv-or-sigbus-errors/
but with OpenMP don't use -heap-arrays, increase the stack with ulimit.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
