I don't get the Output
chimanski__emanuel
given the following code:
program test
Implicit NONE
INTEGER,parameter:: n=130,nt=n-80
REAL*8           :: x
INTEGER          :: i
x=0.0d0
DO i=1,n
   x=x+0.1
   IF(i .ge. 120)THEN
write(*,*)i,x
    pause
    ELSE
   ENDIF
   IF(i.ge.nt)write(*,*)i,x
ENDDO
END Program test
I would not expect to have the following output:
         118   11.8000001758337
         119   11.9000001773238
          50   12.0000001788139
FORTRAN PAUSE
Apparently the value of index i is changing somehow. This is a part of one of my codes I just removed what I could to find the problem, but now I'm left with this and I don't get it. Any other compiler (gcc, or older version of intel) works properly, but the version ifort version 18.0.1  does not.
Any ideia?
Steve_Lionel
Yes - I can see this behavior when optimizing. Looks like a compiler bug. Please report it to the Intel Online Service Center.
chimanski__emanuel
Ok thank you.
I believe this post can be deleted.
All the Best.
