29487 Discussions
recl value exceeds the maximum allowed for the file's record type
psing51
Hi All,
I am trying to run  a program compiled using intel fortran 17.0.5 20170817 compiler  on opensuse 12 having ~512 GB ram. The code -
user@machine1:~/STORE/TESTING/ssmis> cat test.f
       program main
       irecl= 538109432
c      irecl= 2147483647
       open(3,file='obstore.data',form='unformatted',
     &   access='direct',recl=irecl)
       end
here is what i get when i compile & run this code -
user@machine1:~/OBSTORE/TESTING/ssmis> ifort test.f
user@machine1:~/OBSTORE/TESTING/ssmis> ./a.out
forrtl: severe (118): The 'RECL=' value in an OPEN statement for unit 3, file /home/user/STORE/TESTING/ssmis/obstore.data, exceeds the maximum allowed for the file's record type.
Image              PC                Routine            Line        Source
a.out              000000000042AA63  Unknown               Unknown  Unknown
a.out              0000000000408CBE  Unknown               Unknown  Unknown
a.out              00000000004029FE  Unknown               Unknown  Unknown
a.out              000000000040294E  Unknown               Unknown  Unknown
libc-2.22.so       00002B501C0D66E5  __libc_start_main     Unknown  Unknown
a.out              0000000000402869  Unknown               Unknown  Unknown
In function,
    open(3,file='obstore.data',form='unformatted', access='direct',recl=irecl)
If i set irecl to be 10x smaller (53810943) or ,
form = formatted, then code works fine.
  1. What is the "maximum/permissible/allowed"  value of irecl for unformatted file.
  2. Is there a compiler flag through which i can get past the "record length" limitation on unformatted file?
I have already tried integer(kind=8)  for irecl, but the error message was same.
 Please let me know if more information is required from my end.
Eagerly awaiting your replies.
Steve_Lionel
Omit the rec=1 and stream access does exactly what you want. If you need to always overwrite the file, do a REWIND on the unit first. The maximum record length is 2**31-1, as documented under OPEN > RECL.
jimdempseyatthecove
Try:
       program main
       integer(8) :: irecl
c       irecl= 538109432_8
      irecl= 2147483647_8
       end
Jim Dempsey
Steve_Lionel
I am going to guess that you really don't want direct access, but instead are trying to read data without record structure. Please use ACCESS='STREAM' for that.
psing51
as per jim's suggestion  -
user@machine1:~/STORE/TESTING/ssmis> rm a.out
rm: remove regular file 'a.out'? y
user@machine1:~/STORE/TESTING/ssmis> cat test2.f
       program main
       integer(8) :: irecl
      irecl= 2147483647_8
       open(3,file='STORE.data',form='unformatted',
       end
user@machine1:~/STORE/TESTING/ssmis> ifort test2.f
user@machine1:~/STORE/TESTING/ssmis> ./a.out
forrtl: severe (118): The 'RECL=' value in an OPEN statement for unit 3, file /home/user/STORE/TESTING/ssmis/STORE.data, exceeds the maximum allowed for the file's record type.
libc-2.22.so       00002B9A5E41C6E5  __libc_start_main     Unknown  Unknown
as per Steve's suggestion -
user@machine1:~/STORE/TESTING/ssmis> cat test3.f
       program main
       irecl= 538109432
c      irecl= 2147483647
     &   access='stream',recl=irecl)
       end
user@machine1:~/STORE/TESTING/ssmis> ifort test3.f
forrtl: severe (112): RECL= specifier may not be applied to stream access file, unit 3, file /home/user/STORE/TESTING/ssmis/STORE.data
libc-2.22.so       00002ADBB9A7F6E5  __libc_start_main     Unknown  Unknown
user@machine1:~/STORE/TESTING/ssmis> vim test3.f
       program main
       integer(8) :: irecl
       irecl=538109432
c       irecl= 538109432
c      irecl= 2147483647
       end
libc-2.22.so       00002B5E6CFA76E5  __libc_start_main     Unknown  Unknown
I hope i correctly followed your suggestions.
mecej4
From the Fortran 2003 Standard:
9.4.5.12 RECL= specifier in the OPEN statement:... This specifier shall not appear when a file is being connected for stream access.
Just remove the RECL clause from the OPEN statement for the stream file. Note Dave Cutler's derisive "Get a byteget a byteget a byte byte byte" .
psing51
I need to write data as -
       write(3,rec=1)fixhdr,((LDC(i,j),j=1,kcol),i=1,nrow),
     &((RDC(i,j),j=1,kcol),i=1,nrow),((CDC(i,j),j=1,kcol),i=1,nrow),
     &((LUT(i,j),j=1,128),i=1,nrow),(data(i),i=1,ilength)
Which most likely would be incompatible with stream IO.
Is there no way of making the "direct" method work ?
Please let me know if there is an upper limit of irecl,
I will modify the code accordingly.
Steve_Lionel
psing51
Thanks Steve, no runtime errors and i am able to write data.
Now, Need to verify the content of the output file.
