29642 Discussions
ICE for elemental procedure called using a allocatable array of deferred-length character
FlyingHermes
The following code generate an ICE.
It seems to be connected to the used of a allocatable array of deferred-length character as an actual argument to an elemental procedure.
I'm not sure if this is valid nor supported. The error occurs with ifort version 16.0.0, while everything goes smoothly with ifort version 15.0.0
Program Main
  character(:)  ,dimension(:)   ,allocatable    ::      Str1
  allocate( Str1, source = ['This','is','a','string'] )
  Str1  =       Proc_Elemental(Str1)
  contains
  Elemental Function Proc_Elemental(StrInp) result(StrOut)
    character(*)                  ,intent(in)     ::      StrInp
    character(len(StrInp))                        ::      StrOut
    StrOut        =       StrInp
  End Function
End Program
Here is the output with v16:
$ /opt/intel/compilers_and_libraries_2016.0.109/linux/bin/intel64/ifort main.f90
010101_14247
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for main.f90 (code 1)
Fixed in Update 1 (real soon now...)
