ICE + question about realloc_lhs
MR
Dear group,
the following code produces an ICE when compiled with
ifort -assume realloc_lhs test_all.f90 -o test_all
In addition, I would like to ask you if such a code is supposed to
work with the new "reallocate on assignment" f2003 feature or not. The
point is, in this example the rhs is a function returning an
allocatable array, rather than being a variable.
Thank you,
Marco Restelli
0_11517
fortcom: Severe: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for test_all.f90 (code 3)
ifort -V
Intel Fortran Compiler for applications running on Intel 64, Version 10.1 Build 20080602
module my_mod
implicit none
contains
function my_fun(n) result(y)
integer, intent(in) :: n
real, allocatable :: y(:)
integer :: i
allocate(y(n))
y = (/ (real(i),i=1,n) /)
end function my_fun
end module my_mod
program test_all
use my_mod
implicit none
real, allocatable :: ps(:)
!allocate(ps(4))
ps = my_fun(4)
write(*,*) ps
end program test_all
Steven_L_Intel1
This is an problem we're already working on - our issue number is 47419.
