ICE when hypot get two kinds of REAL parameters
A_K_2
Hi, A following program causes ICE. program ice use, intrinsic:: iso_fortran_env, only: OUTPUT_UNIT, REAL64, REAL32 implicit none Real(kind = REAL32):: x Real(kind = REAL64):: y x = 1.0 y = 2.0 write(OUTPUT_UNIT, *) hypot(x, y) stop end program ice
A_K_2
My environment is: $ ifort --version ifort (IFORT) 13.1.0 20130121
Casey
A K. wrote:
My environment is:
$ ifort --version
also causes ICE on 13.1.1 20130313
Steven_L_Intel1
Thanks for reporting this - I have escalated it to development as issue DPD200244767. As I am sure you are aware, a meaningful error should have been given instead, since the standard requires that the two arguments be the same real kind. Or, we might choose to accept the mixture as an extension, as we do for ATAN2.
Steven_L_Intel1
I expect this to be fixed in an update scheduled for October. We will do the same as we do for ATAN2 and promote the smaller kind to the bigger kind.
