I received this error:
bug.F90(56): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
ALLOCATE(FooSubSub :: list(1)%obj)
compilation aborted for bug.F90 (code 3)
This was the code (bug.f90) that generated it:
[plain]MODULE Foos
IMPLICIT NONE
TYPE, ABSTRACT :: Foo
CONTAINS
PROCEDURE(ReturnInts), DEFERRED :: GetGroupInts
PROCEDURE(ReturnInts), DEFERRED :: Dummy
END TYPE Foo
ABSTRACT INTERFACE
FUNCTION ReturnInts(item,nums)
IMPORT :: Foo
CLASS(Foo), INTENT(IN) :: item
INTEGER, INTENT(IN) :: nums(:)
INTEGER :: ReturnInts(SIZE(nums,1))
END FUNCTION ReturnInts
END INTERFACE
TYPE, EXTENDS(Foo) :: FooSub
INTEGER :: ints(3)
CONTAINS
PROCEDURE :: GetGroupInts => GetGroupInts_FooSub
END TYPE FooSub
TYPE, EXTENDS(FooSub) :: FooSubSub
INTEGER :: groups(3)
CONTAINS
PROCEDURE :: GetGroupAdj => GetGroupAdj_FooSubSub
END TYPE FooSubSub
TYPE Bar
CLASS(*), ALLOCATABLE :: obj
END TYPE Bar
CONTAINS
FUNCTION GetGroupInts_FooSub(item,group) RESULT(ints)
IMPLICIT NONE
CLASS(FooSub), INTENT(IN) :: item
INTEGER, INTENT(IN) :: group
INTEGER :: ints(2)
ints = item%ints([1,2])
END FUNCTION GetGroupInts_FooSub
FUNCTION GetGroupAdj_FooSubSub(item,group) RESULT(res)
IMPLICIT NONE
CLASS(FooSubSub), INTENT(IN) :: item
INTEGER :: res
res = item%groups(group)
END FUNCTION GetGroupAdj_FooSubSub
END MODULE Foos
PROGRAM wrapper
USE Foos
IMPLICIT NONE
TYPE(Bar) :: list(3)
END PROGRAM wrapper
[/plain]
There are probably additional syntax errors, but I thought that I should post the crash. I tried paring it down further, but the ICE kept disappearing! For reference, this was on Fedora 11 (x86_64) with ifort11.1 20090511, froml_cprof_p_11.1.038.Thanks!
Jared
Thanks - I can reproduce this and will send it to the developers. The report ID is DPD200137377.
Quoting - Steve Lionel (Intel)
Anytime. Also, I have an ICE on the following, much shorter code:
[plain]PROGRAM bug
IMPLICIT NONE
TYPE, ABSTRACT :: foo
INTEGER :: i
END TYPE foo
TYPE, EXTENDS(foo) :: bar
INTEGER :: j
END TYPE bar
TYPE wrapper
CLASS(foo), ALLOCATABLE :: comp
END TYPE wrapper
CLASS(wrapper), ALLOCATABLE :: obj
ALLOCATE(wrapper :: obj)
ALLOCATE(bar :: obj%comp)
END PROGRAM bug
[/plain]
It might be from the same bug, I don't know. It's probably related though.Regards,
Jared
The bug reported here is expected to be fixed in Update 4, scheduled for mid-December. The second sample you provided is ok in that version.
The ICE for the original source is fixed in 11.1 Update 4, though the compiler now has other complaints about that code - probably due to its being stripped down.
