Hello
The compilation of the following code with/opt/intel/Compiler/11.1/038/bin/ifort results in a catastrophic error:
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.
Thanks in advance
Ben
[plain]module test_module implicit none private public :: new_node type, public :: routing_entry integer :: dst integer :: inter integer :: next_hop end type type, public :: node integer :: id class (routing_entry), allocatable, dimension (:) :: routing_table end type integer, public, save :: node_id = 0 contains function new_node (nbr_routing_entries) result (a_node) integer, intent (in) :: nbr_routing_entries type (node) :: a_node node_id = node_id + 1 a_node % id = node_id allocate (a_node % routing_table (nbr_routing_entries)) end function end module program test_program use test_module implicit none class (node), allocatable :: a_node allocate (a_node, source = new_node (1)) end program[/plain]
Thanks in advance
Ben
Thanks - I can reproduce this. I'll report it to the developers. Issue ID is DPD200137218.
This issue was resolved in 11.1 Update 4, available now.
