catastrophic error 11.1.038
Ben_Lauwens
Hello
The compilation of the following code with/opt/intel/Compiler/11.1/038/bin/ifort results in a catastrophic error:
[plain]module test_module
  implicit none
  private
  public :: new_node
  type, public :: routing_entry
    integer :: dst
    integer :: inter
    integer :: next_hop
  end type
  type, public :: node
    integer :: id
    class (routing_entry), allocatable, dimension (:) :: routing_table
  end type
  integer, public, save :: node_id = 0
contains
  function new_node (nbr_routing_entries) result (a_node)
    integer, intent (in)  :: nbr_routing_entries
    type (node)           :: a_node
    node_id = node_id + 1
    a_node % id = node_id
    allocate (a_node % routing_table (nbr_routing_entries))
  end function
end module
program test_program
  use test_module
  implicit none
  class (node), allocatable :: a_node
  allocate (a_node, source = new_node (1))
end program[/plain]
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.
Thanks in advance
Ben
Steven_L_Intel1
Thanks - I can reproduce this. I'll report it to the developers. Issue ID is DPD200137218.
Steven_L_Intel1
This issue was resolved in 11.1 Update 4, available now.
