ICE with ifort 16.0 with heap-arrays & openmp
Wolf_W_
i stumbled upon an ICE with the Fortran Compiler 16.0.110. The following Code produces the error "fortcom: Fatal: There has been an internal compiler error (C0000005)."
! ifort.exe /nologo /Qopenmp /heap-arrays /module:obj\Release\ /c ICE_OMP_M.f90 /object:obj\Release\ICE_OMP_M.obj
module test_mod
  type :: T_TYPE
    real :: matrix(500,500) ! happens with allocatable, too
  end type T_TYPE
contains
  subroutine calc(this)
    type(T_TYPE), intent(inout) :: this
    integer :: i
    !$omp parallel do
    do i = 2,500
      ! The same happens for minval and maxval (maybe others, too)
      this%matrix(i-1:i,i) = sum(this%matrix(i-1:i,:), dim=2)
    end do
    !$omp end parallel do
  end subroutine calc
end module test_mod
It compiles, if one of the Options /heap-arrays or /Qopenmp is omitted.
This worked well with the 15.x Compiler.
Greetings and thanks,
Wolf
Kevin_D_Intel
Wolf - Thank you for reporting this internal error and for the convenient reproducer. I reproduced and reported to Development and will keep you informed about a fix.
(Internal tracking id: DPD200376051)
Wolf_W_
Update:
This fails with Update 5 of Compiler 15, too.
Kevin_D_Intel
Ok, thank you for the update. I'm sorry to see we regressed on the 15.0 branch. I will update the internal id with your latest update.
