29381 Discussions
ICE with matmul() with -check option
Balint_Aradi
Issue
ICE with Intel classic Fortran compiler. Leaving away the option "-check" solves the issue.
Expected behaviour
Normal compilation of the code below
Observed behaviour
icedemo.f90(8): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for icedemo.f90 (code 1)
How to reproduce
icedemo.f90:
program ice_demo
  implicit none
  integer, parameter :: dp = kind(1.0d0)
  real(dp) :: recVecs2p(3,3), cellMiddle(3), boxMiddle(3), frac(3)
  frac(:) = matmul(boxMiddle - cellMiddle, recVecs2p)
end program ice_demo
compile with
ifort -check icedemo.f90
 Environment
  • Linux/x86_64, CentOS 8
  • ifort (IFORT) 2021.1 Beta 20201112
Barbara_P_Intel
How fortunate!  Another developer reported a similar issue a few months ago.  The Fortran team fixed that in the current release, 2021.2.0.  Your issue is fixed now, too!
Please give it a try and let me know how it works for you.
mecej4
Also with Ifort Version 2021.1.2 Build 20201208_000000 on Windows. No ICE with IFX, but it says, "remark #5415: Feature not yet implemented: Some 'check' options temporarily disabled.".
Barbara_P_Intel
It compiles ok like this
ifort -check -check noshape icedemo.f90
I filed a bug report, CMPLRIL0-33499. Thanks for reporting this. I'll let you know when it's fixed.
Barbara_P_Intel
JohnNichols
Valued Contributor III
Core i7, Windows 11 latest preview, VS 2022 latest, only the latest BASE, HPC and 32 bit MKL - all just reinstalled,  I can see how to fix it, but what is it?
Does not come up in the release version, but one likes to code in debug.
Just out of interest :: How long before IFX is commercially ok?
Barbara_P_Intel
With the release of ifx in oneAPI HPC Toolkit 2022.1, the "beta" label is dropped.  Please read the Release Notes for more information. There is more work to be done.
